2024+ Center-Cooled Touring Models 2023.5+ CVO and 2024+ Road Glide/Street Glide/Street Glide Ultra Center-Cooled Gen 2 M8 Touring models
Skyline Update Technical Support
Old Feb 15, 2025 | 01:08 PM
  #151
Restah's Avatar
Restah
1st Gear
@Navarre Thanks man !! .. It works ...
Due to the fact it was my first HD Update and i was a bit nervous ^^ and didnt want to damage more than needed :P .. Thanks Guys!
Old Feb 15, 2025 | 11:06 PM
  #152
Navarre's Avatar
Navarre
Excellent news Restah! I am glad it worked!
Old Feb 15, 2025 | 11:12 PM
  #153
Taxgod4u's Avatar
Taxgod4u
How large of a thumb drive(s) does this require?
Old Feb 16, 2025 | 12:04 AM
  #154
CharlieMac's Avatar
CharlieMac
I used a SanDisk128 gigabyte USB-C thumb drive and it worked.
Old Feb 16, 2025 | 01:05 AM
  #155
Taxgod4u's Avatar
Taxgod4u
Thanks, will give it a shot. If the power goes out in your town, it was me trying to update the bike.
Old Feb 16, 2025 | 05:37 AM
  #156
Roadie13's Avatar
Roadie13
I use 32 GB drives, the bigger files (disk 2) were just over 8 GB.
Old Feb 16, 2025 | 01:03 PM
  #157
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
For Mac formatting, are you guys choosing the MBR (Master Boot Record) partition scheme? I would think if you’re choosing GUID (which is default), that would be the issue.
@HHKTom you said you got it to work on your Mac?
Old Feb 16, 2025 | 01:42 PM
  #158
HDdrummer's Avatar
HDdrummer
It doesn't give you an option on the MAC as far as I can see to change the format to MBR. It doesn't give you an option on which one to choose. However, if you hover over the partition icon in the usb-c utility, this message pops up: " Disks with Master Boot Record partition maps can't be partitioned " which leads me to believe the usb-c thumb drive is in MBR and not defaulted to GUID.
I am looking forward to HHKTom's response as well.
Old Feb 16, 2025 | 02:54 PM
  #159
rideonva's Avatar
rideonva
All I did on Mac was making sure the filesystem of exFAT type but when copying files there's a little more involved: by default OSX creates hidden folders like .spotlight, which contains indexing information; in my case I've been really thorough and turned off indexing for the thumbdrive and weeded out all hidden folders.
Didn't have a single hiccup during an upgrade.
Old Feb 17, 2025 | 01:57 PM
  #160
Pappy35's Avatar
Pappy35
This thread should be renamed to "Skyline Update Technical Support".
PS - for you sensitive types, I'M KIDDING!
PPS - or am I???
