Drop-in replacement speakers?
Old Mar 10, 2017 | 07:00 AM
OmahaFLHX's Avatar
OmahaFLHX
4th Gear
Default Drop-in replacement speakers?
Looking for advice for drop-in replacement speakers (top-mount like the OEM speakers) for a 2014 FLHXS. BT brackets are out of stock, C-V B52 amp arrived the other day, BT line leveler is en route, just looking for something that will be an easy drop-in install in the factory pods for now. Once I decide on long term speakers with the BT brackets I'll find a use for whatever I stick in the pods now. JL C2?, Focal _____?, Polk, Boston, Kicker, Infinity/JBL? I'm not terribly picky about these, just want something that's not outrageously priced and doesn't require modifying the pods. I've searched the forums and still haven't seen a definitive list of what fits without mods. Thanks!
Old Mar 10, 2017 | 09:40 AM
UltraNutZ's Avatar
UltraNutZ
if you're just waiting on brackets, leave your stock speakers in place, just don't abuse them for the time being.
Old Mar 10, 2017 | 06:50 PM
HD_Doobie's Avatar
HD_Doobie
The Hertz HCX 165 fit perfect. They are no longer made but you could maybe find a used set. Otherwise the Hertz Mille MPX 165 I believe drop in as well. The Polk MM651 are cheap right now as they are being fazed out as well. The Kappas fit on the inside, although I always thought they sounded better on the outside, but mounting on the outside is not recommended
Old Mar 11, 2017 | 08:56 AM
Babyboy's Avatar
Babyboy
If you are looking for a coax speaker to drop in the front pods the only speakers I have ran into that have any issues when mounting on the outside of the pods as the oem speakers are were the infinity kappas.
If you are looking for a component speaker that sounds good in the pods and on the Biketronics brackets is the DIGITAL DESIGN CC6.5. You will only have to mount the tweeter in either the stock grill or an aftermarket grill.
If you use the speaker suggested you will only have to buy them once.
Old Mar 11, 2017 | 06:03 PM
tesnevo's Avatar
tesnevo
Focals coax fit fine
Old Mar 11, 2017 | 08:28 PM
Dsm Limited's Avatar
Dsm Limited
Does anyone know if the AW 65 fits in the stock fairing pods?
Old Mar 11, 2017 | 11:24 PM
Tailwind's Avatar
Tailwind
Would not recommend it. U can do it but need to put a thick washer between the inner fairing and pod to shim it out just a tad.
T
Old Mar 12, 2017 | 09:28 AM
OmahaFLHX's Avatar
OmahaFLHX
4th Gear
Crutchfield has Polk DB651's for $60/pr with free shipping...might give these a try...they'll always fit it in one of my kids' cars if not.
Old Mar 12, 2017 | 09:30 AM
Dsm Limited
T
Does the pod stop good response? Is that why you wouldn't recommend?
I'm looking at CC65 also, just wanted to throw the Aw's out there also. I've read goods things about them here
soulpatch
Apr 4, 2018 07:04 AM
jstar7
May 22, 2016 08:40 AM
chgofirefighter
Audio Systems
Mar 3, 2016 05:56 PM
starbiker99
2014-2024 Touring Models
Sep 29, 2015 07:11 AM
DeathWind
Jul 16, 2006 10:24 PM
