Flat Response Boom Flash
I do not mean to sound like a know it all and I will NOT continue beating this FLASH drum here on HD forums ,,,,,,,
we flash approximately 1,000 Harley radios per year with the J&M custom flash, and I have personally tried it 1,90000 different ways using the latest Harley digital technician down at the local dealer ,,,,,
YOU CAN NO LONGER do it right with the HARLEY digital technician for an aftermarket amp ,,,,,
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
I'm still missing what's so special about ur flash cause all ur doing is exactly what Harley is still capable of providing. They will do the "Ultra" flash and that exactly what u described a few posts prior.
With all ur 1,90000 attempts at flashing, have u really not come up with a better flash than the standard ultra flash? 2 amp and 8 speaks seems to provide the flattest curve and most stabile volume flex thus the discussion about flash customization beyond what the dealers are authorized to provide.
The "trust me cause I have done shix below average 1000 times a year" (for $75 bucks) just won't work around here. These boys are way past the 2 amp 4 speaker ultra flash.
T.
Right now I'm leaning to Haze's recommendation (8/2) and will measure it to see how it compares to stock Ultra Limited (4/0) config. I'd be happy if it took the volume curve out.
FIRST: 4-speakers, upper-fairing, rear-pods, no-amp ,,,,,,
SECOND: ENABLE amp #1
THIRD: Enable amp #2 ,,,,,
that is the flash we use for all J&M ROKKER Stage4 systems ,,,,,,
it lowers the output of the radio, flattens out the EQ, activates the distortion limiters inside the DSP section of the Harley Infotainment radio ,,,,
also turns on rear channel outputs, activates front/rear fade control, bass, treble and auto-volume controls from the radio itself ,,,, (NOT relying upon Harley external amplifiers for these features) ,,,
with the 8-speaker/multiple amplifier flash using the Harley dealer’s digital technician, the radio output is lowered, but the signal is not as clean, and the front/rear fader controls are not activated inside the radio, nor do the bass/treble controls have the same effect ,,,,,
same goes with the AVC control with the Harley dealer flash ,,,,,
the above is free and accurate information that works ,,,,
for those that have access to the Techno-research digital technician, just try it ,,,, you will hear what I have been referring to ,,,,,
if all you have to “bitch” about is J&M charging $75 for the proper flash for your Harley radio, you are missing the whole point ,,,,
jm says can do his flash on mail in I have asked couple times if Alex can do mail in and will ask again Alex can you do your flash on mail in unit.
I suspect there's more guys out there who can do it than you might think. Diag4Bike is in a lot of indy repair shops, they just aren't audio guys. I'd be very surprised if there wasn't a shop within a reasonable distance to you with the tool and software. It's SUPER EASY for them to do even if they've never explored that section of the menus.
Just ask the shops if they have a Diag4Bike computer. Can't hurt to ask around.
