Speakers
Old Apr 11, 2018 | 08:58 PM
Grandslam's Avatar
Grandslam
Default Speakers
I have a 16 Ultra Limited. Can you just replace the stock speakers and significantly upgrade your sounds? Not sure I want to spend a ton of money on an amp and speakers. Any recommendations would be appreciated.
Old Apr 11, 2018 | 09:14 PM
SBates08's Avatar
SBates08
Short answer....No. just replacing speakers will not make an improvement without an amp.
DAVENRINO's Avatar
DAVENRINO
No, but the experts on here can help you with a budget system for 300-400 that will make you smile.
Dave
Old Apr 11, 2018 | 09:16 PM
DAVENRINO's Avatar
DAVENRINO
Bates is one of those experts I mentioned.
Old Apr 11, 2018 | 09:17 PM
travelingypsye's Avatar
travelingypsye
First most aftermarket speakers require more power than the boom system or any (even aftermarket) hu can deliver. Second, on a bike, you need the power of an amp to be able to hear your tunes going down the road. Right now, I will bet you cant hear it well at 70 even with the volume all the way up. Changing speakers only wont gain you any more volume from the hu.
Old Apr 11, 2018 | 09:19 PM
SBates08's Avatar
SBates08
Not hardly brother. Just an enthusiast like most everyone else here.
Old Apr 11, 2018 | 09:23 PM
travelingypsye
An humble too.
Old Apr 11, 2018 | 11:16 PM
giacomo56's Avatar
giacomo56
Would love to see the answer....I have a '17 SGS with lowers.....i would like to add AMP + new speakers on the fairing and maybe two more on the lowers......what would be the best set up and not too expensive....?????
Old Apr 12, 2018 | 06:54 AM
Grandslam's Avatar
Grandslam
OK Bates or anyone else, what do you recommend for those on a budget? The comment about the volume and speed is correct. OK at 70, but when you ramp up to 80, that is a different story.
Will the system be plug and play? Will your system have to be re-flashed?
Old Apr 12, 2018 | 08:05 AM
SBates08's Avatar
SBates08
I just saw that you are in Ms. Where are you located?
