Mmats tuning question - need some trained ears
Old Nov 18, 2018 | 02:58 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Default Mmats tuning question - need some trained ears
Howdy all,
In setting up my PSM I am on the fence about how to set the crossover and EQ settings on my Mmats in the lowers (601.4 models). The website says their frequency range is from 100Hz to 5Khz. When I set the crossover in the PSM to that they sound BAD. I mean real bad. I had run them for a couple of months without any capping of high frequencies at all, just a cut off at 100 Hz or so and liked them fine. I finally settled on capping them at about 15Khz with the high pass setting. Here is a screenshot of the PSM crossover tab, the Mmats are on the middle section with channels 3 and 4:
Also I added a mild EQ curve to tame the vocals and add a little bass. Here is a screenshot of the equalizer settings:
I am sure with my lack of experience these settings are not optimal, it's just what my wax plugged ears came up with. If anyone has any suggestions I would love to hear them.
Thanks y'all.
Old Nov 18, 2018 | 03:40 PM
Tailwind's Avatar
Tailwind
Look at ur plot. I'm gonna bet that with that slope and 4.1 at ur 100hz EQ band, ur digging way deep into frequencies that speaker cannot play. Ur prob crossing 0db at like 70hz. No bueno.
Use the plot. Lower ur EQ #s and use subtractive EQing. 4.1 is a bit aggressive. Qs generally below 1 unless ur specifically targeting certain freqs.
T
Old Nov 18, 2018 | 05:21 PM
Adenton528's Avatar
Adenton528
Hoyt, what does the rest of your setup look like?
Speakers, amps, etc
Old Nov 18, 2018 | 06:04 PM
haze324's Avatar
haze324
Tuning should be a sum of all parts. If I played just a sub or just a compression driver or just a 6.5 it would sound like crap. Your lowers should compliment the rest of the bike not be stand alones.
Old Nov 18, 2018 | 06:14 PM
Hoyt 1911A1
T
Dude, you gotta get out the crayons for me. What do you mean by plot? I think I understand needing to get 100hz reduced a bit, but what do you mean by crossing 0db at 70Hz?
Also I have not changed the Q settings, that's the way they were to begin with I think. How would reducing the Q numbers affect sound?
Haze, what would a good crossover setting for that speaker be?
Thanks again y'all.
Old Nov 18, 2018 | 06:48 PM
FrenchieM's Avatar
FrenchieM
Thanks again y'all.
Plot is the screen that shows your eq curves
Old Nov 18, 2018 | 07:33 PM
Outkast6991's Avatar
Outkast6991
if you boosted the 100hz 4db with a 12db slope that means you dont get to 0db on the slope until around 70hz
Old Nov 18, 2018 | 07:45 PM
Hoyt 1911A1
My problem is I don't understand slopes. I've watched a video about it but still don't quite get it.
Old Nov 18, 2018 | 08:01 PM
Tailwind's Avatar
Tailwind
Also I have not changed the Q settings, that's the way they were to begin with I think. How would reducing the Q numbers affect sound?Haze, what would a good crossover setting for that speaker be?
Thanks again y'all.
Just take ur time and tinker with the program. Click on the Show Plot box and a graph/plot of your programmed EQ settings should show up. U can slide ur cursor around to see where the freqs & dbs are having an impact.
Without question ur gonna need to find the sandbox and wheelhouse of each set of speakers then after u get a feel for their stand alone sandbox dimensions then u can start to tie the sum of all speakers together.
Right now u have those Mmats trying to jam down in the 70s and all the complimenting stages in the world wont make them sound good playing that low, unless u just drown them out completely.
Take ur time brother. It will all come together.
T
Old Nov 18, 2018 | 08:42 PM
Hoyt 1911A1
So is the goal to hit 0db at your cutoff frequency?
Eric Steward
Audio Systems
Jun 23, 2019 11:51 AM
cfave
Audio Systems
34
May 5, 2019 05:51 AM
Hoyt 1911A1
Audio Systems
Oct 27, 2018 06:28 PM
Delgado130
Audio Systems
45
Oct 25, 2018 06:52 AM
Joeymcg
Audio Systems
May 20, 2018 09:21 AM
