09 Road Glide System
Old Jun 9, 2019 | 09:15 AM
fathead1137's Avatar
fathead1137
Default 09 Road Glide System
Hey guys I have an 09 road glide. I will be re doing my current system. The amp I have now is a massive audio 960.4 nano. Will a jl 600/6 fit in the fairing. (Power 8s and 6.5s) and use the massive to power the tweets and horns. Or should I a different route. For reference here’s what I’m trying to power
2 x 6.5s in fairing
2 x DD VO B3 in fairing
2 x 8” speakers in each bag (4 total)
1 horn in each bag (2 total)
1 ARC PSM
Any help is much appreciated. Thanks
Old Jun 9, 2019 | 01:03 PM
Ndfastln's Avatar
Ndfastln
I love those fairings, plenty of room for smaller amps, but not as good for bigger amps. What HU are you running? I have an 08 modified for a double din HU and with some mods to the radio mount you may be able to fit it behind the radio, but I can't swear to it. You can however fit 5 smaller amps in that fairing easy. 1 behind each pocket, 1 on each side of the HU and 1 behind the HU.
Old Jun 9, 2019 | 01:05 PM
fathead1137
I have a Kenwood KMM-BT312U
Old Jun 9, 2019 | 01:39 PM
Ndfastln's Avatar
Ndfastln
With that HU and some cutting on the mount it should fit on top of the radio. But then again I haven't tried that specific amp there. I did have a Soundstream PN1000D there with little mod to the mount.
Old Jun 9, 2019 | 02:18 PM
eaglefan1's Avatar
eaglefan1
I have a 09 RG. Im not running the amp you mentioned. For reference, Im running a SS PN4 1000d in between glove box and inner fairing, Stinger 700 on top of the HU, and a DD DSP mounted like the SS amp but on the other side. Tons of room in there
Old Jun 9, 2019 | 05:32 PM
fathead1137
Will that stinger run 6 speakers pair of 6.5, tweets, and horns
Old Jun 9, 2019 | 05:51 PM
eaglefan1's Avatar
eaglefan1
Not sure. Im sure one of our gurus will chime in and answer that question
Mine is wired to 6.5MMats and a set of horns
Old Jun 9, 2019 | 07:42 PM
Ndfastln's Avatar
Ndfastln
If you run the tweets and horns in mono it would
Old Jun 10, 2019 | 12:27 PM
fathead1137
That's what I was thinking. Anyone know a good shop in the Clarksville/Nashville area that can handle this install. I went to a few shops today and they all said don't use pro audio on bikes. Said thank you and walked out. If not I will be making the trip to dafunkshop
SgtMic
Audio Systems
28
Jun 11, 2017 10:08 AM
509Rider
Audio Systems
May 18, 2016 07:54 PM
Kave Dweller
Audio Systems
Aug 4, 2014 10:54 AM
Harleypingman
Audio Systems
Nov 24, 2010 07:03 AM
