FLHX stereo question
Old Jul 29, 2013 | 01:18 PM
Woofmaster's Avatar
Woofmaster
5th Gear
Default FLHX stereo question
I bought a nice Used 2008 FLHX with a Tourpack installed.
If I remove the Tourpack, my stereo does not work.
Apparantly the Amplifier is under the Tour pack which the Harley people here tell me is not standard and if I wanted to put another one in the fairing, it would be $$ to do that or move it,
I would like to be able to play music without having the Tourpack on all the time. Is there any option other than the $$ one?
Thanks!
Old Jul 29, 2013 | 01:38 PM
1sweetglide08's Avatar
1sweetglide08
Depending on the amp that was installed you can relocate the amp inside the fairing yourself. Give us more detail on the amp...brand, size or pictures.
Old Jul 29, 2013 | 01:47 PM
Dew Me's Avatar
Dew Me
Orrrrrr...you could buy a SECOND amp for the batwing and have the present amp only control rear speakers. You could even ADD speakers. Namely in your lids.
Old Jul 29, 2013 | 02:04 PM
Woofmaster's Avatar
Woofmaster
5th Gear
Ok, will Take some pics tonight and post them up.
Thanks!
Old Jul 29, 2013 | 03:30 PM
Woofmaster's Avatar
Woofmaster
5th Gear
here is the amp under the Tour pack
https://www.dropbox.com/s/ojiium6zhg...28Large%29.jpg
https://www.dropbox.com/s/bal76akv29...28Large%29.jpg
thanks
Old Jul 29, 2013 | 03:38 PM
Woofmaster's Avatar
Woofmaster
5th Gear
saw some used ones on Ebay for $75 and up
Will the existing Harnasses work or will I need to buy another set?
Or just reroute the ones that go to the back?
Old Jul 29, 2013 | 06:18 PM
UltraNutZ's Avatar
UltraNutZ
woofmaster if I'm not mistaken and I'm no expert on these HD/Boom Audio amps..
on the stock head unit only the front outputs of the head unit are used to feed signal to this amp. The amp then seperates the signal internally and feeds both front and rear speakers. There is also some CANBUS stuff to worry about here too that tells the head unit about the amp, etc. This explains why when you detach the tourpak, the front speakers no longer work either.
If Carl, Harleypingman is around he might chime in as well because he knows more about these HD amps than I ever want to know about them.
What I would do is simply disconnect the front speakers in the fairing and don't use those wires for anything.
On the 28 pin connector that's plugged into the back of the head unit, pins 1,2,24,25 are your speaker outputs from the head unit. "Y" those off and feed them into a small amp like the PBR300x2 and wire that to your front speakers. Now this is providing your front speakers can handle this kind of power. If not, I'd replace those too with something like the Biketronics BT7P1 7.1" and be done with it.
Now the other option would be simply to re-route the existing harness for that amp, stick it in a saddlebag and make quick disconnects for your rear speaker pods.
Old Aug 9, 2013 | 12:12 PM
Woofmaster's Avatar
Woofmaster
5th Gear
Thanks! I am going to try to take a look see this weekend,.....wish me, the incompetant mechanic, Luck!
Cheers
rblahetka
Audio Systems
Jul 13, 2017 01:51 PM
speedracer
Nov 15, 2015 06:37 PM
hellbob37
Audio Systems
Jul 7, 2013 05:41 AM
yank721
Audio Systems
May 8, 2013 08:41 PM
Matt1996
Electrical/Lighting/Alarm
Apr 25, 2012 07:22 AM
