The Official 2014 audio upgrade thread
Old Apr 14, 2014 | 07:12 AM
  #361
ChrisHall11's Avatar
ChrisHall11
The Polk MM571's (5"X7") did not fit into the Saddle Bag Speaker Lids for the 2014 SGS. I had to cut out a lot of the basket, and the 4 mounting holes on the speakers did not line up with the mounting holes on the lids.
Just thought I would post this so other 2014 SGS people would be aware.
Cheers,
Chris
Old Apr 14, 2014 | 07:13 AM
  #362
ChrisHall11
I was a little disappointed in HD this weekend. I bought the 2014 Saddle Bag Speaker Lids and the HD Speaker Grills and neither came with screws for attaching grills.
CHEAP.
Cheers,
Chris
Old Apr 14, 2014 | 12:55 PM
  #363
jr3116's Avatar
jr3116
Cheers,
Chris
Just FYI, I installed J&M saddlebag speakers "Plug and Play"
I had to cut a 3" opening in basket and relocate/drill the 2 forward mounting holes.
Old Apr 14, 2014 | 08:30 PM
  #364
JMJOHN's Avatar
JMJOHN
Sponsor
JR ,,, you are correct ,,,, the basket molded into the Harley 2014 saddlebag lids is soo shallow that even the relatively small Noedymium magnet on the J&M ROKKER XX 5X7" speaker is too deep ,,,,,,, so the basket must be drilled ,,,,
but this is the ONLY way to get a quality high-powered speaker into the 2014 Harley saddlebag lids ,,,,, see http://www.jmcorp.com/pdf/HSDR-5X7-1...01-20-2014.pdf ,,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old Apr 14, 2014 | 09:38 PM
  #365
sknyrch's Avatar
sknyrch
My 14 limited is in the shop now having a clutch cable replaced. I hope to get it back tomorrow and I will then begin my Biketronics install. Can I have Harley flash the radio tomorrow for the Two amp setup before I install my system? Or should I wait till all the work is done. It would be nice to have it done while it being worked on. Thanks for any advise!
Old Apr 14, 2014 | 10:41 PM
  #366
firemedic4500's Avatar
firemedic4500
I just installed the Rockford Fosgate Power T400x4ad amp and Hybrid Audio (HAT) Imagine 6.5's in the faring and the HAT 5x7's in the speaker lids. You do have to cut most of the basket on the bag lids to accommodate the magnets and only 2 out of the 4 mounting holes line up. Luckily the mounting holes on the bags are across and opposite of each other and just using two screws, its tight. The 6.5's mount perfect in the pods, just sand down the mounting nub on the pod and use the Boom grills. System is loud and crystal clear, no flash done.
Old Apr 15, 2014 | 01:49 AM
  #367
xbone's Avatar
xbone
Default Audio Upgrade
Well, I am going to pull the trigger and do a upgrade on new street glide. I first bought the boom audio when I purchased the bike. Don't waste your money on this, It looked like something I purchased at toys r us when I opened the box.
I am going with Arc Audio KS125.4 amp and Focal KRC 165's for the front and Focal 5x7's for the back. I will let you guys know how it sounds when done. Reason-I was at a bike show and heard this system in a custom street glide and I have never heard anything better. I know everyone has opinions but the clarity at high volume was unreal!
Attached Thumbnails The Official 2014 audio upgrade thread-img00051-20140321-1809.jpg
Old Apr 15, 2014 | 11:02 AM
  #368
Pioneer74's Avatar
Pioneer74
I thought the new Limited came with a hydraulic clutch?
Old Apr 15, 2014 | 12:18 PM
  #369
sknyrch's Avatar
sknyrch
Pioneer.. It does. It was chaffing on inner fairing. I noticed it when I put new bars on it. Harley just called and it turns out I'm just an idiot though. While the cable had been rubbing on inner fairing it wasn't leaking. It was just the nut that connects the cable to the leaver housing was loose! Cable has been rerouted and should be fine now.
Per my question, I had them flash the radio to the two amp setup while it's there. I should get my BT4180 and Titan II speakers today!! Looking forward to getting it all installed before the Laughlin run in 2 weeks. I will see if John will let me put it side by side with his at the J&M trailer? That could get interesting.
Old Apr 16, 2014 | 12:39 AM
  #370
The Rookie's Avatar
The Rookie
Will the arc 125.4 fit nicely in the front fairing? Does anyone have pictures of this setup?
