The Official 2014 audio upgrade thread
Old May 11, 2014 | 09:17 PM
  #451
bigh8840's Avatar
bigh8840
ok great, thanks for the feedback. in regards to the b-tronics gear. will the 2180 amp be able to support if I do speaker lids down the road? also will it be fine even though I listen to FM radio a lot too... is it plug n play for the 14? thanks for the help and feedback
Old May 11, 2014 | 11:13 PM
  #452
Fatherwayne's Avatar
Fatherwayne
As long as all the speakers are 4 ohm yes it will do 4 speakers. It is not plug and play but the guys at Biketronics will give you all the help you need and then some!
Old May 12, 2014 | 12:07 AM
  #453
xreddirtbanditx's Avatar
xreddirtbanditx
Can someone tell me the harley speaker lid part number?
Old May 12, 2014 | 07:02 AM
  #454
UltraNutZ's Avatar
UltraNutZ
for a 2014?
I don't think anyone has released a speaker lid for 14s yet, but I believe (at least according to their site, Cycle Sounds will be releasing their lids soon.
if pre 14 you're asking about, do yourself a favor; save your money and get the Hogtunes 6x9 lids.
Old May 12, 2014 | 07:27 AM
  #455
Stacy73's Avatar
Stacy73
Went to an HD info system lecture. Had some great new upgrades. Problem for me is I now wear hearing aids. After about 60 mph I start getting a crackling noise no matter how good a system I have. All sound great when I'm not moving or at slow speed. Lucky for me I would rather listen to the engine noise and not the radio.
Old May 12, 2014 | 08:24 AM
  #456
bigh8840's Avatar
bigh8840
Ok big change for me. I just came across a good lead on J&M so.... John if you're reading this or someone who has 14 experience when I jump on J&M website and select 14 I get their performance series 180 or 360 amps. I eventually will add lids. What I'm wanting to know is the 180 enough for that down the road?! It'll be far down the road but I want to be able to potentially be able to upgrade and not have to worry about having to buy a different amp etc... I don't think I can afford the 500w amp. Just checking in. Thanks for all the help gentlemen
Old May 12, 2014 | 01:00 PM
  #457
Fatherwayne
If you are using JM speakers keep in mind they are 2 ohm speakers and most amps are only stable down to 2 ohms so you will have to have a channel for each speaker or run them in series and get less of a draw on the amp. Not knocking the speakers just wanted you to get a 4 channel amp to run them
Old May 12, 2014 | 01:10 PM
  #458
UltraNutZ's Avatar
UltraNutZ
how important is FM reception to you?
Old May 12, 2014 | 01:20 PM
  #459
tlr's Avatar
tlr
Guys,
I am about to install some Focals in fairing and lowers on my 14 SGS> One issue I am having is I cant seem to figure out how to take the glovebox off the lowers. I open the glovebox but dont see any screws or anything else to get them off. Anybody shed some light on this. Thanks
Old May 12, 2014 | 06:16 PM
  #460
bigh8840's Avatar
bigh8840
Pretty important. But I could look into satellite too. Why?! What do I need to look at for that
