Primary upgrade time!
Old Oct 29, 2015 | 05:41 PM
  #91
soft 02's Avatar
soft 02
Originally Posted by HD Pilot
There was a little bang on start up, just figured with all the new stuff, everything just needed to get used to each other - what do you know about that?? Something with the Baker comp??
The initial click into first was very easy and smooth.
No. I don't have a bang on start anymore and it never lurches when putting it in first cold. Smooth as silk.
Old Oct 29, 2015 | 05:42 PM
  #92
Suede Blue Man's Avatar
Suede Blue Man
Good Gawd, leave me alone! Makes me want to put in a 124" just so I have to upgrade!
Sweeeetttt Jesus, nice bits!
Old Oct 29, 2015 | 06:18 PM
  #93
monster715's Avatar
monster715
Great job man! That clutch seems to get better as the miles pile on, I'm runnin about 18oz of fluid right now and I haven't noticed any clutch drag. So you have no new noise coming from the primary at all?? No ticking or like the sound of marbles rolling around??? I think there's something wrong with mine but it's done it since day one. If it ever starts raining I'm sending it back to bandit to have them check it out. It performs great but damn it's loud!
Suede winter time is the best time to do your 124". If you start ordering parts now you'll be tearing up the streets in the spring!
Old Oct 29, 2015 | 06:31 PM
  #94
HD Pilot's Avatar
HD Pilot
Had to go out and start it up again, no "bang" at all this time and like before, a very easy smooth shift into 1st.
Or a Fuel Moto 126"!!
No new noises at all, will keep checking.
Old Oct 30, 2015 | 07:44 AM
  #95
mattVA's Avatar
mattVA
Great job Alan. Looks like a good upgrade and you had fun doing it.
I will add though for others reading this my setup w/ 2014 style SE Compensator, Hayden M6 tensioner, stock clutch w/ beefier spring is pretty darn smooth. Neutral is incredibly easy to find and shifting through the gears isn't so sloppy since changing out my shift linkage to a heim joint design. That fancy clutch of yours really begins to shine with a big inch motor. Speaking of which did you already order a 126" or are you holding out for a Dragon 143"? Go big or go home!
Matt
Old Oct 30, 2015 | 09:19 AM
  #96
HD Pilot's Avatar
HD Pilot
Matt
Thanks Matt! I know if you did not catch me screwing up then I must be doing OK!
After you do your engine build, I bet you are going to need more than the SE clutch spring but maybe you will be OK. I can't remember exactly when my shifting went to annoyingly bad, sometime after my engine build and +1 Alto Carbonite clutch kit install. I just know it was really taking away from the enjoyment of riding and I had to try something.
We will have to agree to disagree on the Hayden chain tensioner. When I read that Baker recommends 5/8" to 7/8" chain movement and my Hayden was piano string tight, I just could not live with it. Maybe yours has broken in nicely, but I was too impatient...just think a super tight chain cannot be good for bearings.
"Go big or go home" ?? Have you changed your mind on your build? Did you sell your 106" cylinders?
You know that I have looked at that FM 126"!! Man that looks awesome, but the co$t when you add in a new throttle body, air cleaner, dyno tune, shipping, etc, etc - probably be $10K easy! For that kinda money one could buy a nice used 2nd Harley. Anyway if I do something it wont be for a year or more. Thinking about wheels/tires/rotors right now...
Old Oct 30, 2015 | 09:41 AM
  #97
mattVA's Avatar
mattVA
Yeah I dunno I'll take a look at mine when I have it apart this winter. If anything I could see going back to stock I'm still not convinced the stock unit is a bad design after reading about the springs it has in there to give it extra movement under load.
No big motors here, 106" for me. I maintain that this little 96" cammed up is plenty for what I do but want to get into the motor for the crankshaft (expensive peace of mind) and for a fun project. Maybe one day I'll have the money to find a used dyna in bad shape and drop a monster motor in it.
Yep I still think second bike is the way to go here. Yours is so nice and you told me yourself you don't need the extra power.
Old Oct 30, 2015 | 09:54 AM
  #98
splattttttt's Avatar
splattttttt
My bike lurches forwars when I start it in gear. What is the cause of it and is it a bad thing?
Old Oct 30, 2015 | 10:05 AM
  #99
soft 02's Avatar
soft 02
Normal. Its parasitic drag from cold fluid and fully immersed clutch discs. A Bandit doesn't have the discs in the fluid and has better clutch to steel separation.
Old Oct 30, 2015 | 10:16 AM
  #100
HD Bobber's Avatar
HD Bobber
When I inspect my primary over the winter I'm going to check to see if my chain has been slapping/hitting any metal on my primary.
I think is fine normal riding, but wide open hotrodding I have the feeling that it give way to much......if that's the case gonna make the switch to the Baker tensioner.
I was just going to add a rear tire over the winter and now I'm getting tire, EBC contour rotors front and back, new diamond engineering rotor & pulley bolts, AND possibly tensioner and baker comp.
NEVER ENDS!
