Primary stuff
It's got 1100 ft lbs in reverse 700 lbs going clockwise
While you're at the pawn shop, get a 3/4 drive socket. Cut it, weld in a piece of pipe for an extension. Then you do't need to rattle the snot out of shlt with an impact driver, or waste the money.
This is just an update on the saga of SBM's winter blues:
So today I installed the Moco 30th pulley, and wouldn't you know it, my old buddy, Buddy F**ker tried to stick his nose in my business in the form of that neat little "Jims" pulley locking tool not fitting on the inner diameter of the 30th pulley vs the larger inner diameter of the stock pulley, see exhibit 1:
The open space inside the pulleys is different the stock one is larger than the 30 tooth which meant that the Jims tool when installed to lock the pulley in place did not alloy for the socket to also fit inside to lock the nut down.
Now my old friend, BF tried to Co** Block me with this move but fortunately the Jims tool is made in two pieces that are bolted together. So I took it apart...
...and used a clamp to hold the pulley teeth portion in place while I torqued it down.
I have to insert here that although the manual did not state it, I took a little paint brush and applied the lightest hint of anti-seize on the splines that the pulley sits on. I was very careful not to apply in more than the splines would hold. I don't think Moco put any on but I just felt it right, damn me if I erred.
Some things come slowly to me, like sleeping overnight on a problem brings the solution, sometimes I have to sleep longer. But clarity came to me when remembering a picture of Matt's Milwaukee impact wrench and I own a Milwaukee drill that supports the same wrench with the same batteries and so bam, ordered one from Amazon and I'll be damned if that little battery powered bugger zipped that nut off like it was nothing.
Let me tell you, getting the nut off (hehe, I said nut-off
You're damn right, I drove that puppy on with the impact wrench and zip-zang, I think I'm good!
I had cleaned the old locktite off the threads of the nut and the shaft with a little wire wheel on my dremel so, nice and clean for the new Loctite.
As you can see I didn't have any Loctite 271 so I used a can of Loctite spray I have. It says it's "200" so I sprayed two coats so that's like 400 so I should be good with that.
Anyway, life is about leverage, so I think I've made it over this hurdle.
So, being the master of leverage I thought I would test my luck with my cheapo HB 1/2" breaker bar, employing my McGruberness at the same time...
...which led to...
Yes, I used an older BMW exhaust has a cheater bar but I fought the law and the law won
The cheater bar worked great, HB did not. That is no doubt, one tough nut to crack but crack it will So I'll head to get the impact wrench tomorrow and see if it works.
If anyone has any recommendations for a moderately/reasonably priced impact wrench please chime in.
