Handlebar vibration
Old Mar 17, 2017 | 03:47 AM
HrdNox's Avatar
HrdNox
Just looking at your set up what I see is essentially a tuning fork (risers) with a weight (clamp) on the end.Just bad harmonics going on I'm thinking. Couple of things I would try. Go ahead with the weights and see what that does. Then I'd check to make sure everything is good with the neck bearings.I would also play with the idle and look for a sweet spot on the bar ends. I'm 100% sure your not the only one that's having issues with similar set ups. Good Luck!
Old Mar 17, 2017 | 07:36 AM
Otter's Avatar
Otter
He’s not, I am too. I agree, I think this is a perfect storm where particular bike setup vs. bar type/size/length is causing an amplification of a particular resonant frequency. I’m no stranger to Harley vibrations, and I’m not particular sensitive to it, but this is killing me, and making my bike hard to ride.
I am ordering a foot of .75” lead rod to give that a shot. If that doesnt do it, then I’ll change bars.
Old Mar 17, 2017 | 07:43 AM
TUCCI's Avatar
TUCCI
My rear cylinder straight shots pipe shook like a mother which bothered me more than the right grip. Its just part of having a Vtwin high displacement motor. Im not sure what to make of the vibration going on in the higher rpms, something else is going on there. Its likely coming from the front motor mount. When my wife rode a 13' FXDC she complained about a horrendous vibration. I trimmed part of the rubber on the mount which took care of most of the vibration. After it broke in, there was only a buzz at the 2500-3000 range. They must have worked that out at the factory because my 16' doesnt buzz at all in that range
Old Mar 17, 2017 | 07:46 AM
Otter's Avatar
Otter
It’s NOT part of having a high dispacement Vtwin. I dont think the motor is making excessive vibration, and I already have a Predator motor mount. This is a bar resonance problem, I’m convinced. We shall see. Unfortinately I have to wait a week and a half for the lead to arrive, but rest assured, when it does I will nerd out post up details.
Old Mar 17, 2017 | 07:52 AM
Otter's Avatar
Otter
I am thinking I will shrink tube each 6” weight and see how tight it fits, if its fairly snug I’ll center drill the rod, and run a 4” deck screw into it to expand it to fit tight. If its not close enough, I think I will get a can of plastic-dip and dip the rod in that and then slide them in and let that set up first.
Old Mar 17, 2017 | 10:01 AM
KSJ08's Avatar
KSJ08
Try "Ride on" in front tire. You'll be surprised.
Old Mar 18, 2017 | 10:21 AM
Otter's Avatar
Otter
Wheel just balanced, and this isnt a wheel balance issue. That kind of vibration/ocillation is totally different than this.
garystaven88
Shovelhead
18
Apr 21, 2019 06:56 PM
Jez78
Feb 19, 2018 07:14 PM
Ironcleveland
May 17, 2015 05:00 PM
Rollon
Jun 18, 2014 06:10 AM
wraplock
Jun 3, 2014 03:04 PM
