Cooling a WG
They do not work well at all on the Twin Cooled bikes. The water pump blocks the air flow to them.
DKCustomProducts.com
Randy
Just ran into a great article on oil temp, head temp and exhaust temp controls on a Harley. The writer ( actually Wards) had sensors installed in the heads and was running air assisted oil cooling and fans on the jugs. Pretty interesting reading if anyone is still following this thread.
Randy
http://wardspartswerks.com/tc-cooling-story.html
Few random thoughts
(1)
My goal - get the temp reading results / deltas - right...., not fast = what the hell ever "right" turns out to be
Maybe this set up works for cooling.., maybe it doesn't
Maybe I needed additional cooling..., maybe I didn't
I dunno at this point..., but I will
(2)
Riding every day..., even a couple of runs thrown in
I've been checking oil temp periodically (with the cooking thermometer)
That got to be such a PITA - I went ahead and bought / installed an oil temp dip stick
So far..., while in TX - oil temp has never went north of 205 - which IMO - ain't hot
BTW:
I did say I would keep my dumb *** opinion out of this thread...., and I also stated I would not buy a temp gauge
So now..., and at this point - I've lied about both of those two
(3)
Until it gets consistently hot enough (air temp wise) - causing the oil temp to get to 220..., or above
Any numbers I post would be (IMO) useless
When it cool (air temp wise) - obviously there no need for add'l cooling
When it hot (air temp wise) - there is (or at least - there may be)
It's when it's hot (air temp wise) and oil temp wise - with the stock set up...
That I'm most interested in
That I'm targeting / testing / reporting..., so other's can make an informed decision on whether add'l cooling is warranted..., or simply bullshit and a waste of good money
(4)
When this thread was most active - there were a few other "cooling" threads fired up
Not interested in the bullshit drama (and frankly it bores the hell out of me)..., only interested in results
Factual..., solid - results..., derived by a methodological / repeatable approach
Maybe I've wasted some money..., and all of our time - I dunno
But once it gets consistently hot around here - we damn sure all will
I will post up some numbers - that is unless I'm killed or busted between now and then - and let the chips fall as they may
Just a little more patience (please) My Man
Jun / Jul / and hotter than hell Aug is right around the corner
eta
I've had to change my oil - still runnin the stock set up..., w/ a stock oil filter - for the initial temp baseline
Ghost
FWIW, I'm good with those numbers. Real or not, it's better then the 300's my PV used to report last summer.
