Stator removal.
Old Apr 18, 2017 | 09:37 AM
JVR's Avatar
JVR
Default Stator removal.
I need to remove the stator on my FXDI. Can I use an impact wrench to remove the sprocket bold. My manual say to use a sprocket tool and breaker bar.
Old Apr 18, 2017 | 10:32 AM
cdndiesel's Avatar
cdndiesel
I replaced my stator just last week and the instructions are right. Use a breaker bar on the compensator bolt and the clutch hub nut. An impact can put hard torsional stresses on both the crankshaft and transmission output shaft. With a good breaker bar and having your bike in a wheel chock, strapped down firmly you won't have a problem. Just a bit of initial effort to break them loose.
Old Apr 18, 2017 | 10:45 AM
Ghost_13's Avatar
Ghost_13
Yes you can..., and I have several times
Will also need to remove the clutch - remember it is left hand threaded
eta - when you install the new stator - RTV the grommet - otherwise it prone to leak
Also remember to use red loctite on the bolt..., and torque in stages..., to 140 FLbs
Ghost
Last edited by Ghost_13; Apr 18, 2017 at 05:43 PM. Reason: mattVA F'd up torque setting
Old Apr 18, 2017 | 11:29 AM
mattVA's Avatar
mattVA
Also remember to use red loctite on the bolt..., and torque in stages..., to 150 FLbs
Ghost
Ghost I know you didn't mean to misinform but the torque spec is bike and application dependent. He could have a late model compensator on a 2006 FXDI which takes I believe 175ft-lb final torque.
Old Apr 18, 2017 | 11:36 AM
Ghost_13's Avatar
Ghost_13
I F'd up by 10 FLbs / whereas mattVA F'd up by 35 FLbs
Will edit my original post to reflect proper torque setting
Ghost
Last edited by Ghost_13; Apr 18, 2017 at 05:44 PM. Reason: Fix this crap once and for all
Old Apr 18, 2017 | 01:14 PM
mattVA's Avatar
mattVA
I F'd up
Thank You Sir
Ghost
Well now it still ain't right. .that 175 is only for one style of compensator. It was just an example.
Old Apr 18, 2017 | 01:20 PM
Ghost_13's Avatar
Ghost_13
On a 2013 WG - it 140 FLbs
Which includes 06 and up
http://baggers.bikernet.com/pages/st....aspx?id=12987
Ghost
Old Apr 18, 2017 | 01:39 PM
blueangel73's Avatar
blueangel73
While you got the comp sprocket out, throw it in the recycling bin and install the Baker Comp Sprocket! You should also recycle that chain tensioner and install the Baker Attitude Adjuster.
Old Apr 18, 2017 | 05:45 PM
Ghost_13's Avatar
Ghost_13
Second this^
Ghost
Old Apr 18, 2017 | 06:29 PM
HrdNox's Avatar
HrdNox
Hell don't stop there!
Put the good stuff in it along with a new regulator.
http://www.cycleelectricinc.com
Scuba10jdl
Mar 8, 2021 01:52 PM
Lockeshill
Feb 25, 2017 10:54 AM
shopnut
Feb 3, 2017 02:58 PM
jonmerrill
22
Nov 24, 2015 12:39 PM
Qjet98
Mar 9, 2007 08:14 PM
