My first Dyna
Old Oct 21, 2017 | 11:28 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Originally Posted by JesseeS
Thank you! And swapping out the turn signals is actually one of the small little details that's next
The Convertible comes with a quick detach windshield as stock. Those turn signals are placed there to reduce "amber lamp reflection" on the inside of the windscreen. If you move them, don't use a windshield at night!
It also comes with~
Highway bars
mid controls
Saddle bags (quick detach)
It's actually a superb platform right from the "get-go."
Dual rotors, steep fork rake, light weight, above features too.
If/when you do a cam, you'll want to replace the OEM Torrington inner cam bearing with an updated Torrington. The stocker usually lasts about 15-25,000 miles before it chews thru the bearing cage. Get to it before this happens.
I had a 1995 FXD for a long time, with a lot more miles than you've got here. The cam I chose to replace the stocker was a Crane 316-2B "Fireball."
It comes on hard at 3400rpm, and signs off at 5500rpm. Cam performed well for the next 100,000+ miles without a hiccup.
Warrior Redleg
May 22, 2018 10:21 AM
Pegster
Mar 11, 2015 06:20 PM
killacomputa
Jul 14, 2013 11:05 PM
chgofirefighter
Jun 13, 2013 03:58 PM
DannyZ71
Mar 27, 2008 10:19 PM
