cam install
Old Nov 16, 2017 | 09:26 PM
MRFREEZE57's Avatar
MRFREEZE57
while the shop service manual is pretty good, that video is very helpful. the manual shows to remove the cam plate, one must remove the oil pump screws where as the video shows is not necessary to disassemble the oil pump saving an extra step.
Old Nov 17, 2017 | 09:57 AM
Jay Guild's Avatar
Jay Guild
Just posting up to agree with others. After labor on removing the tank, rocker covers, and rockers then reinstalling them I think it is worth doing the adjustable pushrods. And like mentioned gives you that much more freedom on cam choice. Depending on how many miles you have on the bike you might want to get the tappets replaced as well.
Old Nov 17, 2017 | 11:23 PM
MRFREEZE57's Avatar
MRFREEZE57
am going to be getting into the cam chest next week, already have a set of S&S premium lifters, S&S quickies and S&S chain tensioner and bearings and bearing removal/install tool. am getting a noisy lifter and decided to do cams at the same time.
found a set of woods 222 cams on E bay that included a set of woods night prowler lifters for $270.00, look like new. will see how it goes, but with the shop manual and help from the S&S video, looks like a strait forward job.
Old Nov 18, 2017 | 01:39 PM
Kraken's Avatar
Kraken
Just note the difference in the video and the instructions on flats to turn the quickie pushrods. I ended up going back in and adjusting them to what the instructions state.
Old Nov 18, 2017 | 11:20 PM
MRFREEZE57's Avatar
MRFREEZE57
that is correct, on the video the guy shows 3.3 turns, where as S&S instructions says use 4 turns.
Old Nov 29, 2020 | 12:36 AM
Joseph Michlig's Avatar
Joseph Michlig
Stage III
Default Andrews 48H is ok with stock pushrods
Originally Posted by chiefy305
Hey all i searched and read lots of post but couldnt find my answer. Are there any cams i can install without changing pushrods and new lifters? just install retune and go.. thank you in advance and plz discuss
i have a 15 streetbob
andrews woods ss or se
great performance for the buck look it up
best low end performance and torque a lifter is .200 deep you want pushrod in the middle but you have a lot of play both ways stock pushrods will put you .080 deep thats fine to 5500 rpm maybe more
Old Nov 29, 2020 | 08:09 AM
Bone Doc's Avatar
Bone Doc
I'd bet he's got it all figured out since he posted this 3 years ago.
sharkchaser
Exhaust System Topics
Nov 30, 2020 07:32 AM
barrygreen
Engine Mechanical Topics
21
Oct 17, 2017 09:41 PM
SniperDude
13
May 12, 2013 07:20 AM
Scramboogie
Dec 4, 2008 10:54 AM
masterblaster
Dec 5, 2007 11:41 AM
