Powdercoating chrome.
Old May 17, 2018 | 11:40 AM
Nicoformica89@aol.com's Avatar
1st Gear
Default Powdercoating chrome.
I rode down to the powder coater to get my chrome primary cover and battery and fuse boxes done black. He didnt want to sand blast them and ruin them. Has anyone powdercoated chrome that can give me some advice?
Old May 17, 2018 | 11:50 AM
misfitJason's Avatar
misfitJason
Powdercoaters don't always like chrome because it's a bitch to sandblast the plating off
Old May 17, 2018 | 11:56 AM
Ghost_13's Avatar
Ghost_13
Find another (competent) powder coater - chrome is actually easier to PC (and holds the PC better) because it has been etched
Have had several chrome pieces PC'd - not one issue
Ghost
Old May 17, 2018 | 12:09 PM
1st Gear
Ghost
Ok Ill look around. Im in the florida keys not alot of options. Do the coat right over the chrome or do they scuff it up first?
Old May 17, 2018 | 12:24 PM
Fatbob bagger's Avatar
Fatbob bagger
I do chrome on a daily basis, literally. Sandblast first then powder. Or sometimes I’ll take a orbital sander and sand the surface with a rough grit. Then powder.
If the blaster isn’t careful he will bubble the chrome, stretch it and then your in trouble. That means that it’s actually lifted from its original surface prep.
so pic and choose wisely if he doesn’t do chrome then find a guy that will.
Old May 17, 2018 | 12:33 PM
Harleywashboy's Avatar
Harleywashboy
If they lift any of the chrome during blasting/sanding, they have to totally remove all of the chrome or it will continue to peel under the powdercoat. Same thing if it's currently rusting through the chrome. Your options are go somewhere else, blast it, or have the chrome electrochemically removed.
Old May 17, 2018 | 12:45 PM
cggorman's Avatar
cggorman
The place I use sends chrome out for chem stripping. We're lucky to have a plating plant nearby.
Old May 17, 2018 | 01:24 PM
Daddy454's Avatar
Daddy454
Nearly everything I have PC'd has been chrome,and never stripped/scuffed a single piece.
Old May 17, 2018 | 02:53 PM
1st Gear
Thanks for all the input. Im going to talk to another guy to get it done right.
nathanw
Feb 10, 2014 08:59 PM
Greg755
Apr 8, 2011 03:08 PM
twhill3
Apr 22, 2009 03:00 PM
hummeld3
Mar 11, 2009 06:56 PM
RoadKingKohn
Feb 18, 2008 03:00 PM
