Most affordable compression adjustable rear shocks?
Old Jan 31, 2019 | 10:29 PM
03f5sp's Avatar
03f5sp
Stage II
Default Most affordable compression adjustable rear shocks?
Long time reader, first time poster. Who makes the most affordable compression adjustable rear shocks for a 2016 Street Bob? I've done searches but couldn' find any threads or posts pertaining to this question. Thanks in advance! Bill.
Old Jan 31, 2019 | 10:34 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Welcome Bill.
Old Feb 1, 2019 | 07:23 AM
Newellhole's Avatar
Newellhole
I’m not sure about most affordable but, I have legends revo-A’s and they are amazing. A little more expensive than the progressive 444’s I had before and it was a night and day difference. I highly recommend legends.
Old Feb 1, 2019 | 04:12 PM
fxdlx's Avatar
fxdlx
Probably Drag Specialties. But the Progressive 412 are not bad shocks too.
https://www.bikebandit.com/aftermark...shocks/p/27126
Just remember the more travel you have the more comfort you have, generally. An 11" 412 with 2" of travel is not going to ride as well as a 13 1/2" 412 with 3" of travel.
Old Feb 2, 2019 | 07:45 AM
rs1250xl's Avatar
rs1250xl
You can only adjust preload on the 412s. I can't say much about budget shocks but for what it is worth I have 412s in 12.5" and I'll be upgrading to Ohlins 763s this summer. 412s helped raising the rear to improve cornering, but they are only slightly better than stock shocks.
OP, what is affordable in your mind? That would provide folks with a budget to give you suggestions on.
Old Feb 3, 2019 | 03:25 PM
Dynaglide92's Avatar
Dynaglide92
Only top of the line shocks have compression adjustment
if you meant rebound adjustability then that’s a different story
Old Feb 3, 2019 | 04:50 PM
TOE_CUTTER's Avatar
TOE_CUTTER
MOST AFFORDABLE? McMaster Carr PN 6092K43.
Drill and tap on your shock a 1/4-20 hole. Screw in above multi-lobe ****. Tell everyone it is for compression adjustment.
Sorry, I couldn't resist. : )
Dave
Old Feb 3, 2019 | 08:21 PM
03f5sp's Avatar
03f5sp
Stage II
I'll have to go a different route, there aren't any that are even close to my budget.
Stock shocks are 12", right? I may just get longer shocks for more travel and call it a day
Old Feb 9, 2019 | 02:18 PM
Wormjello's Avatar
Wormjello
The Progressive Suspension 490 series have adjustable rebound damping. They go for around $679
Old Feb 9, 2019 | 03:06 PM
crusader1xxx's Avatar
crusader1xxx
Go to DK Customs web site are read their review on rear shocks...some good info
GarBare
Nov 24, 2018 09:37 PM
Pnut48
Oct 7, 2018 01:32 PM
showlowzook
Mar 25, 2015 01:12 PM
ebeattie
Jun 19, 2013 01:21 AM
swbob
Apr 24, 2012 04:13 PM
