1994 Dyna Neutral light
Old Nov 17, 2019 | 11:15 PM
cantfindausername's Avatar
cantfindausername
3rd Gear
Default 1994 Dyna Neutral light
Hello. I am new to the forum as well as Dyna HD's. I've got a 94 and when i rev the the engine the neutral light fades out. Is this a sign of an electrical problem like charging and such? It has a new and charged battery.
Thanks for any help!
Old Nov 18, 2019 | 05:33 AM
RANGER73's Avatar
RANGER73
Why are you revving it in neutral?
Old Nov 18, 2019 | 09:12 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
It's not an uncommon issue. There is a neutral switch that has two wires going to it. They have either barrel or spade lugs on it that can get loose over time which causes the light to flicker or go out.
On my 03 the switch is on top of the tranny. The switch has two pins sticking out of it that have two wires with round connectors that push down over the pins. They get loose sometimes and I pinch them with some pliers and put them back on and it solves the problem for a while.
It's a Harley. It's the law in some states.
Old Nov 19, 2019 | 06:13 PM
cantfindausername
3rd Gear
Testing the accelerator pump function as I just recently rebuilt the carb.
Old Nov 19, 2019 | 06:28 PM
cantfindausername
3rd Gear
I was concerned because it is more of a fade out than a flicker from ,say, vibration. Because of this I thought maybe the ignition load was drawing more than the generator could keep up. I guess if that were true the headlight would dim.
VooDoo13
May 24, 2013 10:32 AM
Thomo_Baca
15
Jan 8, 2012 12:24 AM
grumpy56
Dec 27, 2010 07:29 PM
ultraclassicrider
General Topics/Tech Tips
Feb 15, 2007 12:52 AM
Harley Dad
Jul 27, 2005 12:47 AM
