lowering 07 super glide
Old Apr 11, 2008 | 07:15 AM
Jessie's Avatar
Jessie
Default lowering 07 super glide
I was wondering what size progressive shock's I should get to lower 1 inch my 07 super glide ? and is progressive a good shock ?
Old Apr 11, 2008 | 08:11 AM
bikerdog134's Avatar
bikerdog134
Default RE: lowering 07 super glide
stock shocks are 12.5 in. you could use street bob shocks. it would drop ypu about an inch and be a lot cheaper
Old Apr 11, 2008 | 08:20 AM
PowerCobra98's Avatar
PowerCobra98
ORIGINAL: Jessie
Progressive is a real good shock, probably one of the best you can get.
412-4037B/C is a 11" shock and will lower you 1.5 inches. B/C is for black or chrome.
412-4036B/C is an 12" shock and will lower you 0.5 inches.
If you want to split the difference and go 1 inch lower as you stated then you need 418-4837B/C which are 11.5" and drop you 1 inch.
Those are the standard shock part numbers, if you want the heavy duty versions the part numbers are different. You can find all this info on Progressive's website...did you look by chance?
Old Apr 11, 2008 | 08:31 AM
l.ray's Avatar
l.ray
WHY? [sm=chairshot.gif]
Old Apr 11, 2008 | 08:34 AM
jrstar's Avatar
jrstar
You seem to know quiet a bit about shocks. Can you tell me how you think the ride would compare between the stock super glide shock and the 11" progressive shock?
Thank you
Old Apr 11, 2008 | 10:04 AM
RMBLON's Avatar
RMBLON
Couple things to consider lowering, like bikerdog said you can pick up stock StreetBob shocks on ebay or here in the forum classifieds for about $50.00 compared to about $200.00 for progressive, (I have StreetBobs on mine)they are actually 5/8" shorter eye to eye, but because of the angle of the shock the lowering amount is about 1/2". Make sure any bolts holding seats or luggage racks to the fender are as short as possible, so as not to rip a tire, your clearance will be different. Also if you get too low(11") you might need a new Jiffy stand to keep the bike from being to upright. To see how upright your bike will be with lower shocks, put a board equal in thickness to the amount lowering, under the jiffy stand.
Old Apr 11, 2008 | 12:16 PM
PowerCobra98
ORIGINAL: jrstar
Thank you
I guess you're asking me but I'm by no means know a lot. The difference in the Progressive's is three fold.
1. They look cooler
2.They handle different
3. They feel different
1. Looking cooler doesn't need any explanation
2. They are a progressive rate spring which is different than the stock spring. I don't feel like typing out the long version on what a progressive rate means but you can look that up on your own.
3. Because they're a progressive rate spring they feel different over bumps. They hit hard. They're not soft and plush. They're performance oriented; hence progressive rate.
To answer your question, the ride is very different. It's rougher yet more connected; there's no bouncing around. If you're looking for comfort then the stock shock is going to be more comfortable. If you want everything else that a progressive rate shock offers then that's for you.
Somebody else may disagree and say they're more comfortable but mechanically it's impossible for a progressive rate shock to be more comforatable than a non-progressive rate shock. If you don't believe me take a ride in a race car or my Cobra for that matter.
Old May 4, 2008 | 09:19 PM
Jessie's Avatar
Jessie
is 10,000 miles a lot on bob shock's I can get a pair for about 60.00 to the house and would that drop me about an inch ?
Old May 4, 2008 | 10:08 PM
expy's Avatar
expy
Im going for the Air shocks soon. https://www.hdforums.com/m_2920608/tm.htm
Old May 5, 2008 | 03:30 AM
jmpancoast's Avatar
jmpancoast
ORIGINAL: Jessie
I had the Bob shocks on mine before I went to the Progressive 11". As mentioned above, The Bob shocks will only lower you about 1/2", not the inch you stated.
matt_eglide
Mar 25, 2015 10:43 AM
13FXDBinCT
May 15, 2013 06:52 AM
Hot Harley Girl
Sep 21, 2012 11:06 PM
Skid Lid
Jul 11, 2012 09:27 AM
stbobshadow
Jul 17, 2008 12:11 AM
