SEIIs Without Baffles????
Old Apr 8, 2006 | 04:45 AM
kaduku's Avatar
kaduku
Default SEIIs Without Baffles????
SEIIs sound much better than stock, but I may want it louder. I also want to keep the look (which means keeping wthe pipes), so what do you guys think about removing the baffles. I've heard peeps say that it's okay as long as you keep the pipes long. I know some of you have done this, so I really want to hear from all sides.
Old Apr 8, 2006 | 06:12 AM
dynamolowrider's Avatar
dynamolowrider
Default RE: SEIIs Without Baffles????
as long as you tune your scoot to your pipes it wont hurt it but perf. will change . but i have found that with the factory cross over the more you free up the muff. the better it runs as long as you keep your mixture right.
Old Apr 8, 2006 | 08:21 AM
fl_799's Avatar
fl_799
The lack of baffles will lower back pressure too much and create flat spots and torque loss that will be hard or near impossible to tune out. Been there/done that. At the very least, install the big city baffles for the screamin eagle's or some slip in baffles into the header pipe in front of the mufflers if you gut the them.
Old Apr 8, 2006 | 11:19 AM
intruder400ex's Avatar
intruder400ex
get yourself a set of thunder city baffles instead of burnin up your valves.
Steve
Old Apr 8, 2006 | 12:19 PM
wild wally's Avatar
wild wally
I've heard bikes with seii's without the baffles, and imo, it's louder, but not better. It loses some of the low end rumble and is a bit annoying. And you'll be running too lean.
Old Apr 8, 2006 | 12:28 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Can't do it here with any muffler....the LEO's will stick a nightstick up there and if it doesn't hit a baffle.......YOU ARE A WINNER!!
Old Apr 8, 2006 | 01:31 PM
intruder400ex
rleys dont leak do they?
Old Apr 8, 2006 | 03:04 PM
dynamolowrider
fl you are right there is a trade off you do lose tq down low but i tried three diff sets of pipes on my sporty strights sucked even
with tq cones it wasent till i put 2into 1 that i got beter perf. than my stock pipes with guted muff.
intruder you would have to have some pretty short pipes. if that was the case then mill of hds with the old school stright pipes would be dead
polish hammer
Jul 11, 2014 02:29 PM
Streetin
Jun 25, 2013 08:12 PM
Sash302
Mar 19, 2012 10:20 AM
firestop52
Jun 1, 2008 09:33 PM
Dallastx
May 13, 2007 10:55 AM
