what size cables for 16" apes
Old Dec 31, 2008 | 06:16 PM
GONZEE's Avatar
GONZEE
Question what size cables for 16" apes
im installin 16" apes on my wide glide. what length cables do i use? i want to run the wires inside the bars. no clue at the length...HELP!!
Old Dec 31, 2008 | 06:27 PM
BluBob's Avatar
BluBob
Here's some info on a guy doing 17" apes for a Street Bob. https://www.hdforums.com/forum/dyna-...le-length.html
Look at my entry and use the tables on HD's website to determine your stock length, then go about +6. Stock Street Bob mini-apes are 10.25" rise, I believe Wide Glide apes are the same. Good luck.
Old Dec 31, 2008 | 07:58 PM
GONZEE's Avatar
GONZEE
Thanks
Old Dec 31, 2008 | 09:51 PM
Gwjvw's Avatar
Gwjvw
Just watch out! i have seen some wrong ugly lenths before. i would tell ya mine but im away from home, if i remember right they all were +8 or +10 and brake is 50'' but im guessing.
Old Jan 1, 2009 | 07:31 PM
GONZEE's Avatar
GONZEE
i wanna run them through the handle bars so looks r not important
Old Jan 1, 2009 | 07:39 PM
archergodwin's Avatar
archergodwin
You gonna run your cables through your bars? What kind of controls are you using?
Old Jan 2, 2009 | 09:13 AM
Sharknose's Avatar
Sharknose
Here's what I'd do. Take a piece of string and tape one end at the center of the handlebar clamp. Run the string up along the handlebar up to the grip on your current setup and mark it. Now remove the string and tape it to the center point of your new apes and run it up the bars. Mark it where the grip would be. The difference in the two marks should give you a good idea how much over stock length everything should be.
FWIW...When I converted to apes on my FXR, the cables were a snap. It was extending the freakin' WIRING inside the bars that gave me fits.
Old Jan 2, 2009 | 01:04 PM
Gwjvw's Avatar
Gwjvw
For the wires i used the 1' wire extentions! plugnplay!
Old Jan 2, 2009 | 01:08 PM
wkdavistx's Avatar
wkdavistx
I have a 2000 WG with 18" apes and mine are... Clutch 74, brake 52, trottle/idle 41.
The clutch might be an inch or so too long, but it works well.
In my sig pic it still have 14" bars on it.
Old Jan 2, 2009 | 07:10 PM
Baeseman1's Avatar
Baeseman1
Here is a good link. http://www.magnumshielding.com/store/app_search.php
You enter your bike info, and they will show the stock lengths. I have T-bars and wanted shorter lengths, so I got everything -2" from stock.
HWill
Mar 31, 2017 05:37 PM
BSFD932
Aug 16, 2010 01:56 PM
SDMF47
May 21, 2010 11:08 PM
EzStreet
Aug 11, 2009 08:35 PM
WHOSNEXT
Aug 27, 2008 07:25 AM
