HD Front signal relocation
Old Mar 10, 2009 | 03:48 AM
MarksBOB's Avatar
MarksBOB
Best reason for putting a 2" tank lift on.
After I fitted the tank lift I could get to the wiring easy, To do handlebar change and sig relocate.
Old Mar 10, 2009 | 12:48 PM
DGDyna's Avatar
DGDyna
Question Relocation mounting bracket
The instructions say "Place the mounting bracket in position on the lower fork below the triple clamp."
Is there a problem putting them on opposite forks (LH on the right), upside down on top of the triple clamp? That's how I thought it was supposed to be until I saw the brackets were stamped LH and RH.
I'm sure the forks would bottom out first but I still don't like the idea of putting them under the lower fork brace.
Old Mar 10, 2009 | 01:43 PM
MarksBOB's Avatar
MarksBOB
who's brackets are you using, should mount above or below lower tree but we need to know which brackets you are using
Old Mar 10, 2009 | 01:46 PM
DGDyna's Avatar
DGDyna
I'm using the Harley Relocation kit.
You make it sound like I can put it on either side of the clamp. Am I right?
Old Mar 10, 2009 | 01:58 PM
MarksBOB's Avatar
MarksBOB
ok, mine was from Kuryakyn. not sure on the harley clamps, let someone else answer this one, don't want to give you bum info.
my Kuryakyn's mount anywhere on the forks, they were was a 49mm clamp.
sorry I can't help with your install
Old Mar 10, 2009 | 02:12 PM
DGDyna's Avatar
DGDyna
You answered my question. I'm going to mount them above the clamp. It shouldn't make a difference and I'll feel better.
Just so you know, this is on an '09 FXD Super Glide.
Thanks for your help
mac5725
Jan 31, 2013 09:53 AM
YellowHawk
Jul 10, 2009 08:16 PM
dg7080
Feb 10, 2008 05:37 PM
TheGeek
Nov 2, 2007 12:44 PM
grandpawmoses
Nov 24, 2006 01:12 PM
