Side mount plate mounting question
Old Mar 12, 2009 | 09:48 PM
phatman's Avatar
phatman
Default Side mount plate mounting question
Anyone that has a side mount plate where do you have them mounted? What bolt? Any pics? I was thinking about off the shock or the rear upper belt guard bolt. I think it looks a little goofy in some of these spots. Granted it's a horizontal style but I can't seem to make it look right. I want to get this mounted so I can remove the rear plate mount on my 09 bob. I know this may seem like a noob question to some but can ya help a brotha out.
Old Mar 12, 2009 | 09:50 PM
Lorance66's Avatar
Lorance66
I just picked one up off eBay and it bolts to the lower shock bolt. I found some Kuryakyn's that clamp to the swingarm but didn't like the ones I saw, by the way even though they advertise only up to '05 Dynas they fit newer ones too
Old Mar 12, 2009 | 09:56 PM
phatman's Avatar
phatman
Yeah, I already have one from road6customs on ebay. Maybe it's just the horizontal thing that's throwing me off. I Like the vertical style but it's illegal in WI and I don't want to give LEO's any reason to pull me over.
Old Mar 12, 2009 | 10:44 PM
OutlawBagger's Avatar
OutlawBagger
Here's mine. I got it off ebay but I think like you said it's illegal in WI. Mine bolts to the lower shock bolt.
Old Mar 12, 2009 | 10:49 PM
DeathProof72's Avatar
DeathProof72
Some bolt to the left side wheel axle bolt.
Old Mar 13, 2009 | 07:04 AM
dpriest's Avatar
dpriest
made mine from diamond plate and angle. bolts to the rear lower shock bolt. had to use a slightly longer bolt
Old Mar 13, 2009 | 09:06 AM
panic_fan's Avatar
panic_fan
I made one from 3/16 steel plate and some angle iron. Tucked it in tight so the inside edge is flush with the inside of the swing arm. Had to go with a longer bolt too.
Attached Thumbnails Side mount plate mounting question-374370176_1292015768_0.jpg   Side mount plate mounting question-374370398_1292016604_0.jpg
Old Mar 13, 2009 | 09:37 AM
r00k's Avatar
r00k
Mine is bolted to the axle.
I got it from http://www.dreamweaversprostreet.com/upgrade.htm
Old Mar 13, 2009 | 11:48 AM
coachstorms's Avatar
coachstorms
bolted to the rear bolt of the belt guard.
Fastfwd
Aug 4, 2013 11:02 AM
machm1969
Nov 29, 2012 02:39 PM
1BadAssBob
Dec 22, 2009 05:02 AM
whodatfan
Mar 16, 2009 01:28 PM
meyergsr
May 24, 2008 08:46 AM
