Sears red jack modification
Old Apr 9, 2013 | 10:18 AM
  #541
lo-rider's Avatar
lo-rider
Fear mongering? Scaring the crap out of people? Come on.
It has been a long time since I modified mine so I don't remember the bolt size required. But I recall someone in the thread boring out their holes way oversize, which can weaken the walls of the lifting arms.
My word of caution applies also to those who are unnecessarily increasing the cantilever by installing large or multiple spacers with extra-long bolts. Just use your head when making mods and you'll be OK.
Old May 19, 2013 | 05:14 PM
  #542
Ventana's Avatar
Ventana
Just happened to notice that the 2013 wide glide has a 4" ground clearance. I guess that would put this jack out of the running for this bike. anyone know for sure?
Old May 19, 2013 | 05:32 PM
  #543
HD Pilot's Avatar
HD Pilot
I'm away from home right now(so cannot measure mine), but SC-Longhair early on in this thread said the height from floor to top of pads is 5 1/8".
Old May 19, 2013 | 05:36 PM
  #544
Ventana's Avatar
Ventana
Yes, I saw that but I'm thinking the ground clearance is measured to the lowest part on the bike (probably the oil pan). I'm wondering if there is much difference between the frame and oil-pan height.
Old May 19, 2013 | 06:05 PM
  #545
skinman13's Avatar
skinman13
I just bought one of those lifts and modified it...$8 and change for bolts, washers, and lock nuts, and about 30 minutes time. No power tools, just a hacksaw to cut the cross bar out, a flat file to smooth out the rough edges of the cut, put it back together with the four 6" X 1/2 inch bolts with the cut sides on the outside instead of the inside and it slid right under my SG and lifted it up pretty as pie.
The best part is that I saw the lift on a shelf in my local Sears store while I was waiting for a battery for the Thunderbird. It was the only one they had left and it had a sale sticker marked down to $79.99 regularly $119.95. It's great to get a good deal when I am not looking for one.
Old May 19, 2013 | 06:13 PM
  #546
SC-Longhair's Avatar
SC-Longhair
Ventana, I'm sure the frame is no different underneath on a '13 WG and a '12 Fatbob (which my bud owns). I've used my jack on his as a test and had zero issue. Lifted the bike just as designed. Not sure if you own a '13 WG or are in the market for one but I'd think you could tighten up the shocks (to the 5th setting) and gain a small bit of ground clearance. I don't know how much.
I could double check the height of the jack if need be.
Old May 19, 2013 | 06:14 PM
  #547
SC-Longhair
Darn good deal, if you ask me.
Old May 19, 2013 | 08:02 PM
  #548
lo-rider's Avatar
lo-rider
It's not likely that you'll find a much lower lift. If the Sears won't slide under it, just put a low block under the jiffy stand and/or roll one or both tires up onto a piece of plywood or 2x4.
Old May 19, 2013 | 08:04 PM
  #549
Ventana's Avatar
Ventana
Nah, I was looking at a new wide glide but decided to keep my FXDXi at least another season.
After revisiting this thread, I purchased a Sears Jack this week and will do the mod next weekend. Not sure if I'm gonna have issues with my FXDX as it is lowered with Progressive 11" shocks. I'm hoping it won't be a problem as the FXDX starts out with more ground clearance the other dynas. The on-line specs don't really correspond to my real world measurements. Not sure why but on-line says the stock ground clearance is 5.9". When i got down there and measured from the ground to the frame it was 7" and the seat height was 29".
I'm 5' 9" with a 29" inseam and the height was starting to give me problems. I'm a lot older now and had some major surgery the last 3 years. I wasn't feeling comfortable so i was looking to get a lower sitting bike. I really couldn't justify the 17K right now for a new Wideglide so I put about $300 into lowering the FXDX to about the same specs that the new wide glides had. Anyway, I'll do the mod as it's a great one and deal with getting the jack under there with some of the suggestions I've read here.
BTW, I could see and hear your frustration in your second video. All i can say is, to each his own and you shouldn't feel you need to defend your mod. People can do it or not do it any way the wish. You did good. One of the really useful mods I've seen.
Old May 19, 2013 | 08:33 PM
  #550
dBone's Avatar
dBone
3rd Gear
Glad I found this thread my sears jack has been a dust collector.
