Sears red jack modification
Old Apr 8, 2013 | 11:47 AM
  #531
bobnehoc's Avatar
bobnehoc
Originally Posted by SC-Longhair
Congratulations. No one likes a troll.
Is your bike lowered? If so, the mod won't help you there. I'm not sure I'd put the kickstand up. One of these days you're going to forget and lower the bike off the jack and .......
Excellent.
The bike is a stock height LowRider. The jack was hitting the kick stand and I could not slide the jack in far enough. I pushed the jack in as far as it would go and then I got on the bike and stood her up and closed the stand. I pushed the jack the rest of the way under the bike and it worked perfectly. I will try and remember that the stand is up when I lower her down....Thanks Again. I might try and move the front support bar back further to avoid the kick stand but I did not feel like cutting and welding the front bar. I might due that mod later but I wanted to get on with the business at hand and get the work done that was needed so I could ride.....
Old Apr 8, 2013 | 11:48 AM
  #532
milesvdustin's Avatar
milesvdustin
The problem is the bolt head hits on that kickstand protrusion. If I move it forward, the rear pad tries to hit the oil pan. I just grabbed four more 1/2" spacers at the hardware store, I'm going to give it a go after work and hope for success. If not, I'm going to try again with 1/2" bolts and longer spacers.
Old Apr 8, 2013 | 03:36 PM
  #533
milesvdustin
Yep so I'm a dumbass. I didn't have enough spacers for my jack. I now have 1/2" on the pad in the rear and 1" on the front pad. Just tried it out and it worked great. I'm going to convert to 1/2" hardware all the way through instead of the 7/16" stuff. I need longer bolts on the front now anyways. And cut the middle front rubber off the top of the pad to clear my clutch cable a bit more, just in case.
Old Apr 8, 2013 | 04:29 PM
  #534
SquidHead's Avatar
SquidHead
Since we're extrending to load bearing part of the jack further out, I highly recommend using the stronger 1/2" hardware.
Old Apr 8, 2013 | 06:06 PM
  #535
milesvdustin
Yep, I stated in my post I'm converting it over to all 1/2" hardware. Gonna use the grade 8 stuff for sure. It will be all 1/2" stuff before I use it again. I think I have a narrower jack than the original, saw some discussion in here about that. At least I solved the issue!
Old Apr 8, 2013 | 07:54 PM
  #536
Bagger_Vance's Avatar
Bagger_Vance
I don't know about the Sears width when you modify it but when I added washers for spacers and used 5" grade 8 bolts the width from outside to outside on my HF is 21".
Old Apr 8, 2013 | 10:22 PM
  #537
lo-rider's Avatar
lo-rider
... I'm going to try again with 1/2" bolts and longer spacers.
Be aware that increasing bolt size weakens the lifting arms.
Old Apr 9, 2013 | 05:47 AM
  #538
SC-Longhair's Avatar
SC-Longhair
You'd be better to be concerned with the In-In measurement since most of what we are trying to dodge will fit in between the pads, not outside of them.
Old Apr 9, 2013 | 06:01 AM
  #539
SC-Longhair
Really? I remember when I reamed out the holes to accommodate 1/2" hardware. A minimum of material was needed to be removed.
The stock hardware was smaller and I'm sure it was grade 2.
Again...the jack is rated for 1500lbs, and the Dyna weighs approx 50% of that, wet. I just don't subscribe to the mild fear-mongering you're trying to bestow. Obviously making the mod is up to the end-user. If you choose not to do it, great but stop trying to scare the crap out of people.
Don't you remember seeing the photos of 8541Hog's modded jack lifting his car?
Old Apr 9, 2013 | 07:10 AM
  #540
milesvdustin
The 7/16" hardware has a loose fit in the holes already. Maybe a 1/32" loose. Barely, but its there. So opening the holes another 1/32" to 1/16" to accomodate a set of 1/2" hardware is removing barely any material at all. Plus, the jack has to be stronger with the bolts fitting the holes without slop in them. Less levering torque action on them. Many here have done it in 1/2", I will too. Mine works with 7/16", but I'll feel better with tighter fitting bolts and its only going to cost me another ten bucks. Still way far ahead of buying a more expensive jack.
Thank you to SC for originally modding this years ago and thank you to all the advice from others in here.
