Cams
Old May 28, 2010 | 09:37 PM
  #111
SURFOR Chop's Avatar
SURFOR Chop
Vic
You said you disabled the O2 sensors ...?
Is there an auto-tune for Power Commander III ...? If so, it might make sense to just reinstall the O2 sensors and add the AT to the PCIII, might be more cost effective ....
Just thinking out loud ....
Another thought ... if the dynojet map makes it rideable, just use that as a starting point and compare where the differences were between it and your previous map ... then make minor adjustments accordingly ... [not sure if I properly explained my concept] ....
R/
'Chop
Old May 28, 2010 | 10:04 PM
  #112
SC-Longhair's Avatar
SC-Longhair
Originally Posted by SURFOR Chop
Vic
R/
'Chop
No, Chop...no AT for the PCIII.
That idea about about comparing the maps and then making changes accordingly was spot on. I understand what you're saying. I definitely think the fuelmoto map was way too rich in the low end.
I could probably build the map at home and then try it out. Rock on!
Besides, I could sell my pistol (S&W model 4566 .45acp w/ 4 extended clips). Either way I can get it tuned or the TTS.
Old May 28, 2010 | 10:37 PM
  #113
8541hog's Avatar
8541hog
Hmmmmmm
Old May 28, 2010 | 10:46 PM
  #114
SC-Longhair
Rich, you know you can't just post "Hmmmmm" without elaborating on it.
Old May 28, 2010 | 10:52 PM
  #115
Grind's Avatar
Grind
Hmmmmmm
Old May 28, 2010 | 10:53 PM
  #116
SURFOR Chop
Vic -
I'm a little surprised someone hasn't volunteered that they have a map that matches your setup ... T/H, Woods 6-6 and Big sucker (?) ... doesn't seem like you have such an obscure combination that you couldn't find a map ... have you done an expanded search to include some of the other 'competitor' forums ...?
R/
'Chop
Old May 28, 2010 | 10:59 PM
  #117
SC-Longhair
I've posted in other sub-forums asking that same question and have had zero hits.
I have not hit any of the 'other' forums.
Old May 28, 2010 | 11:00 PM
  #118
SC-Longhair
Originally Posted by Grind
Hmmmmmm
It's the Bopsy twins.
Old May 28, 2010 | 11:06 PM
  #119
8541hog's Avatar
8541hog
Sure i can.....
Old May 28, 2010 | 11:07 PM
  #120
8541hog's Avatar
8541hog
Would you like me to take a look at your maps?
