Cams
Old May 25, 2010 | 11:13 PM
  #81
SURFOR Chop's Avatar
SURFOR Chop
No ... mines different ... spring loaded vice hydraulic ... saw a great feature on how to at http://www.harleyhog.co.uk/camguidepage1.htm ... the third photo illustrates the difference pretty well ....
R/
'Chop
Old May 25, 2010 | 11:16 PM
  #82
SC-Longhair's Avatar
SC-Longhair
Yeah, definitely different. I bet you could use a nail to lock it away from the chain.
Old May 25, 2010 | 11:26 PM
  #83
SC-Longhair
Hey, looking at that pic...the 4* advance gear I have will probably work for you if you want it.
Old May 26, 2010 | 05:57 AM
  #84
adlerx's Avatar
adlerx
Just did the woods 6-6 w/+4* gear monday/tuesday. Spent all afternoon trying different SERT maps, only one good enough to actually test ride. WOW! Waht a difference! Unfortunatley, that map worked pretty well at near WOT but is not really one I can use.
I'll get it sorted out to be rideable.
Have dyno tune scheduled in about just over two weeks.
If anyone has a map they could share for the 6-6 w+4*/96"/stock heads, Love to see it. Doesn't matter what format, SERT/SEPST/TTS as I can copy table values. Would really like to ride this baby while waiting for dyno.
You are gonna love it SC!
Old May 26, 2010 | 06:25 AM
  #85
SC-Longhair
Appreciate that input, Adler. I've always heard good things about this cam as a bolt in. Obviously I don't expect huge gains but I do foresee just a little added fun in riding.
Old May 26, 2010 | 06:49 AM
  #86
Airborne350G's Avatar
Airborne350G
Originally Posted by SURFOR Chop
So ... did you get the tank on and fire that bad boy up ...? I'm dying to hear a run report ....
I ordered my gasket kit ... also ordered a S&S crankcase breather valve that goes outboard (I believe) of the oil pump on the end of the crankshaft ... supposed to significantly reduce the air pressure that forces oil into the head breathers ... and into the intake ....
Decided to hold off on ordering the special tools ... saw a video where a guy used his oven and freezer to 'size' the cams, bearings and cam plate to obviate the necessity of the hydraulic press ... I'm trying to conceptualize how to de-tension the cam chain tensioners ... I'll think of something I suppose ....
Now ... get crackin' and finish up your cam job ... give us (me) some inspiration ....
R/
'Chop
Wasn't sure about the crankcase breather so I had to search on it. I found this on the net and it is pretty interesting:
""First off the breather only lets the engine breath one direction, this was fine from Flat Head days to EVO days but the Twin Cam motor is an internal breathing motor. This means the TC breaths from the crank case to the cam chest and then up to the rocker boxes when the piston is on the down stroke, (very little air escapes the engine through the two small holes in the head breather bolts) as the piston goes up the bore the air is pulled out of the top end into the cam chest and through the pinion bearing into the crank case again. During the up stroke of the piston and air traveling into the crank case there is a pull on the oil in the top end that assist in the return of that said oil into the cam chest for removal. If you install the S&S breather it only allows the air to pass through the bearing from the crank case to the cam chest one way....now as the piston goes up the bore the breather stops the air from cycling back through assisting in oil drain from the top and causing a vacuum in the crank case which you DON'T need with this Twin Cam breathing design. Now the oil has to return by gravity alone which slows the return process so oil can be actually filling the rocker boxes. All the oil is directed into the cam chest now in the TC not the Crank case. EVO's and earlier Harley's the oil from the top end was directed into the crank case and their breathers where designed to make that vacuum in the crank case to assist in oil return from the top end. (there are other reasons for crank case vacuum too but thats another topic)
Bottom line in my opinion the S&S breather is just another way to get you to shoot the lock off your wallet....it's not needed and it's a waist of time and money. It doesn't help in scavenging oil out of the cam chest back to the oil tank and that is the ONLY way to prevent oil carry over....get the oil back to the tank.""
Old May 27, 2010 | 05:56 PM
  #87
SC-Longhair
Well....fired it up today. Nice thump.
It runs like crap though. Lots of sputtering in 1st and 2nd gear. I have a video that is uploading now. Will post shortly.
I'm not 100% sure I got everything timed correctly. I may be pulling it apart again.
I'm also not 100% sure on the map that fuelmoto sent me. Of course there is no comments on the map other than the fuelmoto stamp.
Old May 27, 2010 | 06:49 PM
  #88
SC-Longhair
Default Wood TW6-6 cams
Here's the video:
http://www.youtube.com/watch?v=zQT2mMQEaqw
Old May 27, 2010 | 06:57 PM
  #89
DCamm94's Avatar
DCamm94
Sounds great. Nice and low. Love the lope.
Old May 27, 2010 | 07:08 PM
  #90
lhcstreetbob's Avatar
lhcstreetbob
nice job on the pipe it looks good.... that sounds about how mine did at idle with my andrews 54s ..
