Exhaust question
Old Jun 25, 2010 | 01:07 PM
mike300's Avatar
mike300
1st Gear
Default Exhaust question
Hey everyone,
I just posted this question in the general because I didn't see the dyna section at first so Ill probably get yelled at so anywho, my '07 fxd was not loud enough so I pulled the mufflers, great sound now! so to try to keep the look till I can afford pipes we drilled the caps in the muffler,put them back on not loud enough, so I took them off again. How soon do I need to go get it dialed in so I don't screw anything up? sounds good, runs good but I'm sure the lack of backpressure jacks with the cpu.
Thanks, Mike
Old Jun 25, 2010 | 02:24 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Mike, welcome to the forum. There's tons of threads on this topic if you do a search.
You should be fine to run open pipes for a while as long as you keep your stock air cleaner. I know a few guys that have done this and have had no problems.
Old Jun 25, 2010 | 02:28 PM
jaysonL's Avatar
jaysonL
Open headers ? Not sure I would want to do that . These bikes are overly lean from the factory . Running those short open headers , with zero back pressure can't be good .
Old Jun 25, 2010 | 02:37 PM
mike300's Avatar
mike300
1st Gear
Thanks guys for the reply's just don't have the cash for a set of pipes and it didn't sound much like a Harley to me it was a tad old manish.
Old Jun 25, 2010 | 03:18 PM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
The bike will run 14.6 in the closed loop areas provided your O2 sensors are still intact. This will likely be about 80% or more of your riding. The areas set to closed loop might run a tad lean.
Old Jun 25, 2010 | 03:36 PM
VsTheWorld's Avatar
VsTheWorld
if you're worried about engine problems then put the mufflers back on - if you dont have cash for some used slipons, you sure don't want to add any additional repairs to the list of upcoming bills
mike300's Avatar
mike300
1st Gear
O2 sensors were not touched just took off the stock slip ons, but boy does it sound mean.
Old Jun 25, 2010 | 04:39 PM
maddghost's Avatar
maddghost
BCT baffs should run you between 40 and 60 $$. Look in the HDforums classifieds someone is always selling **** cheap. If you were in canada you could have a crack at my rush 175's
Old Jun 25, 2010 | 07:45 PM
U-234's Avatar
U-234
Did you see the Phat Performance Bud 7 exhausts thread? Slip ons are $160 and full 2 into 2 for $275. It's in the Dyna section.
TommyRumRunner
Apr 21, 2017 07:57 PM
JFife72
Apr 10, 2011 10:06 PM
OhioSkully
Exhaust System Topics
Feb 7, 2008 04:35 PM
cecil1
Mar 20, 2007 02:49 PM
GulfWarVet
Jul 25, 2005 08:46 PM
