Belt broke while riding...cause?
Old May 22, 2011 | 08:29 PM
fendrjgstng94's Avatar
fendrjgstng94
Default Belt broke while riding...cause?
So me and a few buddies were taking a little ride this evening and all of a sudden while down shifting my belt broke on my 00 super glide (owned it for 3 months). As far as I know, no problems with the bike and I havent had one since Ive been riding it.
We were going about 25-30mph slowing down to a stop light, and to anticipate the stop i started to down shift. When i was going from second to first it kind of got a little tight and made a popping noise between 2nd and neutral, the popping was kind of like the gears in the transmission werent really engaging and just bouncing off each other. So i gave it an extra bump to get it into 1st and all of a sudden the belt snapped right off.
Luckily i was able to pull of to a side street and 3 of my buddies stayed with me while the other 2 rode back and got a trailer.
But the question is, what happened? Did the transmission seize and forced the belt to snap off? My buddy said sometimes he doesnt even bother to put his bike into first until hes at a dead stop because his transmission wont let him. The belt looked fairly new and even had the HD symbol visible on it. After I change the belt should I inspect the bike further?
Thanks
Old May 22, 2011 | 08:34 PM
SC-Longhair's Avatar
SC-Longhair
If it's the original belt, that would make it ~11yrs old. It could have just been worn out. It does happen. Other than that, I can't offer any rationale cause. Sorry.
EDIT--- maybe the belt was too tight?
Old May 22, 2011 | 08:39 PM
JBourquin's Avatar
JBourquin
Start the bike and put it in gear and let the clutch out. Does the front pulley spin? If it stalls, you've got some tranny problems. Could have just binded up for some unknown reason. Did the bike lunge like the rear momentarily locked up just before it broke? I know it takes some good torque to break these belts, but it's not at all impossible.
Old May 22, 2011 | 08:44 PM
Wild Card's Avatar
Wild Card
prolly some debrise got in there. don't care about gaurds it happens, my buddies RK went through 2 in 6 months. I am getting ready to do one on my 01 WG I just picked up, it has a bad spot.
Old May 22, 2011 | 08:45 PM
Spanners39's Avatar
Spanners39
They are more likely to snap if they are too loose but can go at any time between 10K and 100K.
Old May 22, 2011 | 09:01 PM
fendrjgstng94
possibly
ill try that method.
the bike was just riding normal down the road when it snapped, like i said before the gears grinded a bit and when i put it in first you heard the tranny make a noise kind of like i was down shifting, but a lil louder and the belt broke.
also another question. what is a good replacement belt to get and how many teeth? 133?
Old May 22, 2011 | 09:29 PM
bigmikaele's Avatar
bigmikaele
Sorry to hear about your belt, hope it was only the belt and you are back on the road quickly. I know my bike has been on the lift for a week. Got a flat, went to replace the the wheel only to see the ***** on the belt were split 90% through (~50K miles on it), neither of the two closest dealerships carried belts in stock so had to order one and it finally came in this past Friday. Spent the day yesterday putting a new one on and now waiting on a new pulley as mine was worn and scalloped on the pulling edges. Changing the belt wasn't too bad. I took pics along the way if your interested.
Old May 22, 2011 | 09:39 PM
bikerlaw's Avatar
bikerlaw
Does the bike still have the belt guard? Maybe a rock or road debris got up in it and popped a hole in the belt at some time in the past. After riding with a puncture long enough, it might have just given out.
Old May 23, 2011 | 02:02 AM
lo-rider's Avatar
lo-rider
Originally Posted by fendrjgstng94
...We were going about 25-30mph slowing down to a stop light, and to anticipate the stop i started to down shift. When i was going from second to first it kind of got a little tight and made a popping noise between 2nd and neutral...So i gave it an extra bump to get it into 1st and all of a sudden the belt snapped right off...
Sounds like you were going way too fast for a downshift to 1st.
Old May 23, 2011 | 03:02 AM
Stiggy's Avatar
Stiggy
If it wasn't debris from the road, then your belt was probably too loose. Belts will give a little laterally but won't stretch at all. If you jumped a tooth, you broke the belt. I keep mine taut, but not tight. 89,000 miles and 11 years old, ( so far!)
