Question about bottom left shock bolt
Old Aug 9, 2011 | 02:36 PM
kevinb62's Avatar
kevinb62
Default Question about bottom left shock bolt
Can anyone tell me if an '06 streetbob has a nut on the bottom bolt for the shock?
was pulling mine apart when I came across this. The right side did not have one so I"m
starting to think the last shop that replaced my tire may have stripped the mounting hole.
Did 'nt see it in the manual either unless I overlooked it.
Old Aug 9, 2011 | 02:59 PM
trip20's Avatar
trip20
I have an 07 Wide Glide..... but mine has a nut on the left, and a threaded mounting flange on the right (no nut).
Old Aug 9, 2011 | 03:03 PM
kevinb62's Avatar
kevinb62
Thanks, wasn't really sure.
Old Aug 9, 2011 | 03:07 PM
trip20's Avatar
trip20
Mine isn't the same bike as yours, but it's a Dyna so likely the same. Someone with an 06 Street Bob will hopefully stop in to confirm for you.
Old Aug 9, 2011 | 03:28 PM
8541hog's Avatar
8541hog
This is where a parts manual is invaluable, it gives you an exploded diagram of all parts so you know what and where things should be.
Sorry I only have the 05 Dyna parts manual and the frame changed in 06
Old Aug 9, 2011 | 03:33 PM
Mascman's Avatar
Mascman
2006 Bob and it's the same...nut and bolt on shifter side with bolt only on brake side.
Old Aug 9, 2011 | 05:19 PM
Shovelhed's Avatar
Shovelhed
Same here...
Old Aug 9, 2011 | 07:17 PM
WS6 Formula's Avatar
WS6 Formula
Item #2 http://partsfinder.onlinemicrofiche....=13&A=479&B=30
Originally Posted by WS6 Formula
Part Numbers:
http://partsfinder.onlinemicrofiche....m_oem/hdmc.asp
Find your year, model, part, then put a 1 in the qty box of the item or items that you want the part number of, then click on "add items to parts list", then click on "send to cart" to get the part number.
95sporty33
Feb 11, 2018 11:52 AM
shore
General Topics/Tech Tips
Nov 18, 2016 09:09 AM
DallasSportster
Jun 17, 2009 03:06 AM
fastfxrs
Aug 16, 2008 09:02 AM
Nach
Jan 25, 2007 12:49 PM
