Key is loose?
Old Aug 15, 2011 | 08:14 PM
big poppy's Avatar
big poppy
Default Key is loose?
I have a 2008 streetbob the ignition has loosed and is almost fallen out. Do any of you know how to tighten it back up? help please.
Old Aug 15, 2011 | 08:16 PM
Brewtality's Avatar
Brewtality
is it the key or ignition that is loose?
Old Aug 15, 2011 | 08:24 PM
big poppy's Avatar
big poppy
the ignition is loose.
Old Aug 15, 2011 | 08:26 PM
blink1968's Avatar
blink1968
ignition loose?
Old Aug 15, 2011 | 08:34 PM
RANGER73's Avatar
RANGER73
Take off the center console (where the speedo is) by loosening the bolt in the middle. And tighten everything under there. Use blue locktight when you put it back tigether.
Old Aug 15, 2011 | 08:36 PM
Brewtality's Avatar
Brewtality
08 streetbob has the ignition in the neck.
Not sure how to tighten it.
Old Aug 15, 2011 | 08:50 PM
SuperFastGlide's Avatar
SuperFastGlide
turn the ring around the ignition counter clock wise
Old Aug 15, 2011 | 09:27 PM
big poppy's Avatar
big poppy
thanks it worked.
Old Aug 15, 2011 | 09:39 PM
08fxdf43202's Avatar
08fxdf43202
The trim ring that has the lettering on it is glued on. Remove it a use a spanner wrench to tighten it then reglue the trim ring.
I have no ide what king of glue to use... my friend left it off.
T-town Pig
Jun 20, 2019 11:09 PM
Ashnic
General Topics/Tech Tips
14
Jun 6, 2019 11:37 AM
flhxmc
Feb 22, 2013 09:53 AM
Terp84Alum
Jun 9, 2010 06:03 AM
superdog48
Feb 15, 2006 12:09 PM
