Subsequent Failures IPB after "Full Monte" Fix
Old Oct 11, 2011 | 06:16 PM
Sammi's Avatar
Sammi
Default Subsequent Failures IPB after "Full Monte" Fix
Bringing bike in next week for "Full Monte" fix to IPB. This is the 3rd failure and the dealership has H-D approval for fix with '07 cases.
Hopefully this is it!!!
Curious if anyone had a IPB failure after new cases and bearing were installed?
Thanks,
Sammi
Old Oct 11, 2011 | 07:54 PM
Shovelhed's Avatar
Shovelhed
https://www.hdforums.com/forum/dyna-...and-cause.html
This thread might help you, but fortunately mines good...
Old Oct 12, 2011 | 11:03 AM
doorsidedown's Avatar
doorsidedown
I had mine completely fixed about a year and a half ago - 9,000 miles later, not a peep. This seems to completely fix the problem... Happy to hear they're doing it for you.
Old Oct 12, 2011 | 01:51 PM
kk6pg's Avatar
kk6pg
Another question you could ask is how many failures have been reported in MY 2007 and up. Trust me, the problem isnt "fixed". Its only a lesser failure rate than the 06. Even the Baker bearing isnt turning out to be the end of it, the way I thought it would.
Old Oct 12, 2011 | 01:57 PM
parts eeter's Avatar
parts eeter
Personally I went with the Baker bearing. I still consider it to be a normal maintainence item that I will replace annually during the off season.
Its easier to knock out the Baker bearing than deal with the press fit race on the Timken style OEM setup.
Old Oct 12, 2011 | 04:43 PM
jamman's Avatar
jamman
damn i was lucky then , first one went out at 7700, 06, they replaced it , and never made a sound, til i traded it off at 40k.. good luck on the next one..
Old Oct 13, 2011 | 02:35 PM
Bspike1's Avatar
Bspike1
what kind of sounds should I be listening for with IPB failure?
Old Oct 13, 2011 | 02:52 PM
Sammi's Avatar
Sammi
"what kind of sounds should I be listening for with IPB failure?"
Sounds like a bad throw-out bearing on a car - like a spinning metal wheel on a roller skate. Starts out as a faint sound, and gets progessively more noticeable as time goes by.
You can hear it when bike is in neutral and clutch is out. Whirling noise goes away when clutch is in and bike is in gear.
Sammi
Old Oct 13, 2011 | 03:00 PM
PHA-Q's Avatar
PHA-Q
06 here with 13,500 miles and mine has never been an issue.. Of course now that i said that..... It'll go!!!!!
Old Oct 13, 2011 | 03:09 PM
Spanners39's Avatar
Spanners39
I use a Dremel so that I can get the inner race off without removing the sprocket and even if you use a bearing puller the suckers sometimes still need to be cut off.
Mind you don't go through to the gear shaft, just cut two grooves 180 degrees apart and tap the groove with a chisel....then remove the race by hand :-)
PoCoBob
Aug 14, 2013 06:04 PM
Lyfer
Jun 20, 2012 12:49 AM
makoshark333
Sep 13, 2007 06:01 AM
WillieC
Jul 21, 2006 08:26 AM
dhutchison
Jul 3, 2006 03:51 PM
