Project FXDXT is underway
Old Jun 1, 2012 | 01:32 PM
  #91
sonnydaze's Avatar
sonnydaze
Originally Posted by Hogpro
Going to have to change the jetting in teh carb as well as I am sure that will c ool it sdown a bit. Right now it has a 180 main and a 45 pilot which I thought was perfect but I am getting low RPM deceleration popping too. First I'll adjust the afr screw and if that does not work the jetting will be swapped. For anyone else with a bike in this year range and a carb, what jetting are you running, and how many turns out do you have on your afr screw? I think mine is at 2 or 2.5 right now which should be optimum but it most definitely is not. The only other thought I have is that the intake manifold gaskets could be shot which is very possible as the gas mileage is far from great with the current setup and i would think it is running way rich but the plugs say different.
Once again hindsight is 20/20 as I should have changed the intake manifold gaskets while I had the tank off. I even have the gaskets already.
dont know what gear drive cams i have as po put them in , but im running 200 main and 48 slow , stock is 190 and 45 , air fuel is 2 1/4 out .
what happenend to painting the inside of pipes with ceramic coat to cut down heat ?
Old Jun 1, 2012 | 01:37 PM
  #92
Hogpro's Avatar
Hogpro
Former Sponsor
The jet hot is still an option. Maybe I do have stock jets then. Hmmm. I'll have to pull it apart again make sure I remembered the jet numbers correctly. I think a twist on the afr screw will help too. Thanks for the info.
Old Jun 1, 2012 | 01:38 PM
  #93
sonnydaze's Avatar
sonnydaze
I s there room to pull the choke out with tank on the bike?
yes there is room
[IMG][/IMG]
Old Jun 1, 2012 | 01:42 PM
  #94
sonnydaze's Avatar
sonnydaze
i use 3 coats of vht ceramic coat on inside of pipes , under 10 bucks and works well keeping heat down
Old Jun 1, 2012 | 01:44 PM
  #95
Hogpro's Avatar
Hogpro
Former Sponsor
That is an option as well. The jet hot is pricey. Not sure how much of the inside of the thunderheader I can get to with a spray can as it is all one piece unlike your pipe. Thoughts?
Old Jun 1, 2012 | 01:49 PM
  #96
sonnydaze's Avatar
sonnydaze
hmm see your point , if you could get it in a can bet you could roll it around in pipe
Old Jun 1, 2012 | 02:06 PM
  #97
Hogpro's Avatar
Hogpro
Former Sponsor
There is an idea. I'll have to figure something out as this pipe gets hot. Maybe this will work.
http://www.google.com/products/catal...d=0CKoBEPMCMAg
Old Jun 1, 2012 | 02:09 PM
  #98
Hogpro's Avatar
Hogpro
Former Sponsor
Even better.
http://www.eastwood.com/ew-hi-temp-i...ension-tu.html
Old Jun 1, 2012 | 02:13 PM
  #99
sonnydaze's Avatar
sonnydaze
i might try that on my servi car build , looks like it would be cheap and easy
Old Jun 1, 2012 | 02:16 PM
  #100
sonnydaze's Avatar
sonnydaze
i think if you bump your jets up youll be surprised how much cooler it runs , but id still coat inside of pipes to keep them cool
