Push start and "click"
Old Sep 7, 2012 | 09:24 AM
  #51
Austin Dave's Avatar
Austin Dave
If you have the Battery Tender branded unit, you're good. None better. Keeping the battery in a fully-charged status is the way to go. I keep my BT Jr hooked-up when my bike is 'resting'.
Old Sep 7, 2012 | 10:18 PM
  #52
JT-FXDL's Avatar
JT-FXDL
Originally Posted by j1mmy
if a jumpstart worked, the starter is fine. sounds like a bad battery or cable. it only takes a few volts for the lights and solenoids to work,it takes a lot more to turn the starter. could be as simple as a loose or bad batt cable not carrying enough amps.
Could you explain why you think the starter is good if a jump-start worked? Wait, when I say jump-start, I don't mean jumper cables, but rather pushing the bike up to some (relative) speed, jumping on the seat and popping the clutch.
Old Sep 7, 2012 | 10:23 PM
  #53
lo-rider's Avatar
lo-rider
That is a "push" start, not a jump start.
A "jump" start involves jumper cables.
Old Sep 7, 2012 | 10:24 PM
  #54
Dynaglide68's Avatar
Dynaglide68
It's your starter because your getting power from the battery .... , if your lights go down when you go to start it then it's your battery if when you try to start it and the light's don't change then it's your starter ......
Old Sep 7, 2012 | 10:38 PM
  #55
JT-FXDL's Avatar
JT-FXDL
LOL... Where I'm from, in a car, it would be a push start. On a bike its a jump start. Using jumper cables, or "booster cables" is known as a boost or a boost-start. Sorry, but that's how we say it from my neck of the woods
Old Sep 7, 2012 | 10:40 PM
  #56
JT-FXDL's Avatar
JT-FXDL
You got it! It did turn out to be the starter. Gold star for you!
Old Sep 7, 2012 | 10:45 PM
  #57
lo-rider's Avatar
lo-rider
Well, everywhere else using jumper cables is a jump start.
Old Sep 7, 2012 | 10:53 PM
  #58
JT-FXDL's Avatar
JT-FXDL
I guess I'm just used to the Mainah talk.
firefour
Jan 31, 2017 02:11 PM
chopped7
Apr 25, 2015 09:49 AM
bikerlaw
EVO
Aug 9, 2010 12:28 AM
kokopelli372
General Topics/Tech Tips
Dec 17, 2009 08:51 AM
ape.hanger883
Aug 21, 2008 08:49 PM
