torque specs
Old Jan 23, 2007 | 08:05 PM
riderj's Avatar
riderj
3rd Gear
Default torque specs
what the torque specs and pattern to tighten them on a 81 shovelhead primary case because it leaks like crazy. i have gone though 4 gaskets
Old Jan 24, 2007 | 07:46 PM
riderj's Avatar
riderj
3rd Gear
Default RE: torque specs
what isthe torque specs and pattern to tightenthe boltson a 81 shovelhead primary case. because it leaks like crazy. i have gone though 4 gaskets.someone please tell me
Old Jan 24, 2007 | 09:01 PM
thrillseeker's Avatar
thrillseeker
I don't know
I don't know
An official response from the Department of Redudancy Department.
Old Jan 24, 2007 | 10:13 PM
06dynablack's Avatar
06dynablack
riderj couple good sites are for shovels http://www.virtual-cycles.com/forum/viewforum.php?f=18and msn good shovel brd there also
Old Jan 25, 2007 | 10:06 AM
stubby's Avatar
stubby
One thing I remember about shovel primary covers is they leak. I had purchased a chrome cover to find the thing leaked non stop. I was able to take my stock cover and have it chromed. That sealed pretty good. This goes back a way for me, but I remember the harley gasket was a cork gasket. I was able to purchase a rubber gasket that worked well.
Starting with your bottom bolt tighten across the cover, back and forth. Get the cover hand snug then torque around 110 inch lbs.
Old Sep 1, 2018 | 07:44 AM
cowboy45's Avatar
cowboy45
Stage III
marydoes anyone know where i can find the torque specs for an 09 street glide inner and outer primary
Old Sep 1, 2018 | 09:38 AM
WildPhrog's Avatar
WildPhrog
Check the service manual...you can dig them up pretty easily if you google it. You used to be able to buy hard copies of them from the dealer for a reasonable amount, but they recently jacked up the prices crazy high....still might not hurt to ask seeing as you’re looking for info on an 09. I was able to download a pdf for my 2017 for around $10 after a quick google search.
Old Sep 1, 2018 | 12:14 PM
nevil's Avatar
nevil
If you're working on the inner primary you should be referring to the shop manual, and not just for the torque specs.
Old Sep 1, 2018 | 01:00 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
You could ask Max Middelbosch over here: https://www.ammh.nl/contact/contact.php?pid=2
Old Sep 1, 2018 | 05:21 PM
Boostedboxer04's Avatar
Boostedboxer04
A quick Google search would produce an answer for ya
blueridge
Aug 4, 2024 06:20 AM
Jeremy Belko
2018+ Softail Models
28
Jun 16, 2019 08:23 PM
soft 02
Aug 24, 2013 03:44 PM
riderj
Jan 23, 2007 07:48 PM
picwick
May 9, 2005 02:03 AM
