Engine start up timing
Old Mar 26, 2013 | 11:57 AM
highmarket's Avatar
highmarket
Default Engine start up timing
I have a 2003 Dyna wide glide with 103cu, 211 cams high 10.5 comp. carburated with manual comp release, it is tough on starter clutches, is there any way to reduce start up timing? I`ve read that there is on newer EFI models with a PC.
Any help would be much appreciated.
Old Mar 26, 2013 | 03:28 PM
Spanners39's Avatar
Spanners39
I would install compression releases or the lo-ratio starter set up. Timing probably won't help much with that comp ratio.
Old Mar 26, 2013 | 03:43 PM
dyna rider's Avatar
dyna rider
Default HP/Torque
Any idea what kind of numbers you are making with that setup ?
Old Mar 26, 2013 | 03:48 PM
Spud17's Avatar
Spud17
Try pushing in your compression releases lol, but seriously it shouldn't be going through the starter clutch with compression releases.
Old Mar 26, 2013 | 04:48 PM
highmarket's Avatar
highmarket
It won`t even start with out pushing in the comp releases hot, new battery and high torque starter.
Old Mar 26, 2013 | 04:50 PM
highmarket's Avatar
highmarket
it has comp releases, I`ll look into lower ratio gear, thanks
Old Mar 26, 2013 | 04:51 PM
highmarket's Avatar
highmarket
Never had it on Dyno.
Old Mar 26, 2013 | 09:59 PM
dyna rider's Avatar
dyna rider
Default HP/Torque
My TC88 went through some mods and became 95cu in with the 211 cams and HC pistons.The dyno said 85hp/93torque. Just wondered what the difference would be with a 103 and the same set up...
Dazzauk
Mar 24, 2016 02:41 PM
uptop42
Sep 23, 2010 08:20 PM
gnaz
Exhaust System Topics
Jun 13, 2009 11:51 PM
paco ritter
May 7, 2009 02:34 PM
ggoubaud
Nov 10, 2007 01:35 PM
