Handlebars, NOT internally wired
Old Jun 9, 2013 | 03:32 AM
sonnydaze's Avatar
sonnydaze
Originally Posted by 8541hog
Never have used the chain, I tie a small nut to a string and drop it through to get things started. The nut just helps it fall through.
try a 2 foot piece of ceiling fan chain , it sure makes it easy
Old Jun 9, 2013 | 03:35 AM
8541hog's Avatar
8541hog
My way is very easy, and I always have string around and it's free. Thanks though.
Old Jun 14, 2013 | 11:14 AM
Angie D300's Avatar
Angie D300
Originally Posted by brandon95354
drill your own bars its easy, also you do not need to take apart the connectors as mentioned. you have a 2012 dyna in 2012 the dyna models stopped using the old style bulky connectors, they now use small connectors. i have ran the wires with connectors attached threw rsd vintage apes and west coast 12 inch mx bars.
so read the directions, and dont stress on taking apart the connectors..skip that step.
https://www.hdforums.com/m_262490/tm.htm
dont worry about your wires shorting out when ran internally, take your time do it right...itll be fine
Thanks for all the advice...i'm definitely going with internal wiring, just because it will look neater. May have to attempt drilling the holes myself because i can't seem to find the exact kind of bars i want that have everything i want (black, dimpled, knurled, 5-6" pullback AND DRILLED)...at least not for under $150. Yeah, i'm picky
Old Jun 14, 2013 | 04:43 PM
xantasm's Avatar
xantasm
When I swapped from the stock drag bars on my 2011 fat bob I tried going to 1" drag bars and didn't like them so got 35 degree Flanders drag bars and decided hell with it and to externally wire the controls and ran into this problem:
The hand controls either need to be cut down some where the bar meets the formed mount or the bar needs to be dimpled underneath to allow for the thickness of the wiring bundle to pass through without crimping and possibly severing the wires as the hand controls are tightened down onto the bar. As they were originally setup to run internally there is no adequate opening to allow the wires to pass between the ridges of the control housing and the bar.
Old Jun 14, 2013 | 05:10 PM
INJEKTER's Avatar
INJEKTER
IF you drill, make sure the openings are big enough and that you remove any sharp edges that can skin the wires.....removing the pins from the housings is super easy and way faster than cutting and then soldering back together....whole thing is pretty simple really n-joy....working on your own bike is the way to go...
Old Jun 15, 2013 | 11:44 AM
Angie D300's Avatar
Angie D300
I'd probably run into the same prob because my setup is originally internally wired, and the bundle of wires is pretty thick too.
I found some Flanders that will be perfect...they're like $140 (little more than what i wanted to spend, but they got it all).
Old Jun 15, 2013 | 11:48 AM
Angie D300's Avatar
Angie D300
will do...if i do get the pre-drilled bars, i may have to do a little more drilling anyways. i've noticed that the holes in some of these bars are tiny. my current bars have a hole (oval) that's about 1 inch wide.
Anyways, if it was up to me, i'd just have a Fat Bob like you, and be done with all this tHanks for the advice!!
yokdriver
Aug 31, 2014 12:37 AM
scottystreetbob
Mar 30, 2013 11:29 AM
0ut1aw
Mar 14, 2008 11:32 PM
paulie
Dec 20, 2007 04:13 PM
ACE75
Nov 8, 2006 09:24 PM
