oil level prob ?
Old Jun 19, 2013 | 11:35 PM
bosscarr's Avatar
bosscarr
Default oil level prob ?
Hello I have a 2003 fxdwg and my oil level cold has always been in the middle of the stick and when hot it would show full this is doing it by the book on the jiffy stand and when hot letting it idle few min. Well now when cold cold on jiffy stand in the middle but when hot shows a quarter down fron full any help Thanks ps bought it little over a year ago with 1600 miles now have 8000
Old Jun 20, 2013 | 07:25 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
I'd let it go, that is the way these bikes are. That many miles with only that much usage I would say is good. You certainly do not want to overfill these engines or you will have unwanted consequences.
Old Jun 20, 2013 | 11:51 AM
dirtdobber's Avatar
dirtdobber
Read your owners manual.
Old Jun 20, 2013 | 12:31 PM
Grendel4's Avatar
Grendel4
If you're going by the book and checking the oil when it's hot... And you're doing everything else right and your dip stick is accruate and properly installed......
And the dipstick is showing it's low -- It's low.
The HD Motor is a pretty big motor to only have three quarts of oil in it. Especially when you consider it's air-cooled. You don't want it to be too low for any length of time.
As to over-filling it? Not good but not fatal unless you overfill it by a lot. And remember, it's easier to add oil than it is to remove it.
It's still a dry sump system. But don't overfill it. Right on the money is always best
Old Jun 20, 2013 | 05:26 PM
bosscarr's Avatar
bosscarr
Default Thanks
Thanks alot everyone who responded I will check it hot and that is the one I will believe
Old Jun 20, 2013 | 05:30 PM
DesertDyna's Avatar
DesertDyna
you will know if you get it too full...you will start spittin oil into your air filter when its hot!
Old Jun 20, 2013 | 05:36 PM
SuperFastGlide's Avatar
SuperFastGlide
mine runs about 2 xs down on the stick... if i fill it to the top i get a little blow by
Old Jun 20, 2013 | 08:54 PM
maddghost's Avatar
maddghost
Maybe you checked it hot after a few minutes of idling, and either didn't wait for the oil to drip down, or you inadvertently forgot to screw the dipstic down snug before unscrewing it again to check your level. If it's showing half full cold there is no way other way it will show low when hot unless a bunch leaked out without your knowledge,
one way or the other your supposed to check it cold. If it's half or more your good.
matthew6279
2014-2024 Touring Models
24
Jul 30, 2017 07:14 AM
Pcrebuilder
Aug 8, 2014 02:17 PM
bosscarr
Welcome Area Only
Jun 20, 2013 06:06 PM
bzxgdk
Sep 19, 2009 02:09 PM
PHAT A$$
May 1, 2009 10:25 PM
