FXDB Wheelies!
I want a wheelie machine. the bike came with a Vance & Hines dual exhaust. and some cheap fuel pack.
I'm thinking about changing my pulleys to a different size next
Should I go up a couple teeth in the rear.. or go down a couple in the front?
I want that extra torque but i still want to be able to hit 100mph without the bike sounding like its going to blow.
Any suggestions would help!
Thanks
13.5" rear shocks, chain drive, +2" fork tubes, and drop rear tire pressure to 35psi, and having a softer compound tire helps, 2nd gear rev a little to get rpms up while hovering over seat drop down pull back and dump clutch at the same time again in 2nd gear she will be a wheelie machine that's almost everyone setup and risers and bars that are comfy and at the right height for you to get the pull on usually around 6"-8" risers an 2" bars that are like dirtbike bars..some even do use protapers and other dirtbike bars the pullback or not on risers is all preference to the rider
