Engine Build Time
Old Mar 25, 2014 | 01:49 PM
  #481
HD Pilot's Avatar
HD Pilot
As Matt stated, you do feel a "thump" when the top o-ring seats.
Before that I put the front cylinder on Top Dead Center by watching the lifters: exhaust up/down then intake up/down then plastic straw in front spark plug hole keep rotating wheel same direction until straw extends to the maximum - TDC.
For S&S prs with the S&S lifters that have the HL2T travel Limiters you extend the prs until they are seated on the lifters and rocker arms then extend them 4 more turns. Basically the first 3 turns take the space left in the lifters ~ .085", then the next turn will start to open the valves(you can really feel the resistance go up when you start to open a valve). This is because my lifters are not "pumped up" with oil - I had dumped the oil when I dissembled my lifters earlier. If I had "pumped up" lifters, the 4 rotations would be opening the valves right away. I could just finish adjusting my lifters now but I thought I would wait a bit to be extra safe.
To adjust the prs I will loosen them until they are just moveable with finger pressure then loosen 1 full turn(6 flats) then tighten the locknut down.
Old Mar 25, 2014 | 07:46 PM
  #482
HD Pilot's Avatar
HD Pilot
Got my prs in and adjusted, must say I really like the design of the S&S prs - simple to adjust and work with. Those push rod clips were a bit of a pain but doable, for me the exhaust clips were much easier than the intake ones. I waited to install the rocker covers until after the prs because it was nice to see the prs hit the rocker cup to be sure they were in the right spot. Anyway, making progress but rest of week is sketchy for time, have a lot of family stuff coming up.
Old Mar 25, 2014 | 08:01 PM
  #483
soft 02's Avatar
soft 02
Coming along! I just hit 500 miles on mine with NO issues! Hoping the same goes for you!
Old Mar 26, 2014 | 01:46 PM
  #484
Thomas Eckenrod's Avatar
Thomas Eckenrod
Nice write up Alan i have been following the whole thread. I have about 300 miles on my build from my AMS 96 kit . They do good machine work i'm happy
Old Mar 26, 2014 | 02:32 PM
  #485
HD Pilot's Avatar
HD Pilot
Thanks, good to hear, not a lot of info about them but I sure enjoyed working with Eric - he is a busy man but he is easy to work with.
Not too much happening right now, just been cleaning all my air cleaner parts in preparation foe the HPI 55mm throttle body install.
Old Mar 26, 2014 | 02:38 PM
  #486
soft 02's Avatar
soft 02
Are you using the 5.3 injectors?
Old Mar 26, 2014 | 02:48 PM
  #487
HD Pilot's Avatar
HD Pilot
Yes, guess you saw my HTT thread...they seem to think no problem.
Old Mar 26, 2014 | 02:52 PM
  #488
soft 02's Avatar
soft 02
I did not but 5.3 woulda been my choice too. Thats what came with my SE 50mm.
Old Mar 26, 2014 | 03:19 PM
  #489
HD Pilot's Avatar
HD Pilot
Yeah, I asked the HTT crowd if they thought the 5.3s might be too big, but they all said no problem and to run em.
Old Mar 26, 2014 | 03:21 PM
  #490
soft 02's Avatar
soft 02
Hind sight I shoulda got the HPI unit.
