Vibra-Technics motor mount install
Old Jul 21, 2014 | 08:17 PM
  #211
br549A1's Avatar
br549A1
Originally Posted by chickenhauler
Yes rear mount checked by a tech.
Just check it yourself with a mirror and a flashing you can see right up and can feel the space with your fingers. Techs are good but if they don't think something is your problem they aren't looking like you would on your own bike
Old Jul 21, 2014 | 08:31 PM
  #212
br549A1's Avatar
br549A1
Here's a few pictures you can see the clevis is reversed from yours and although hard to see in the photo, with a mirror and flashlight you can inspect the rear mount easily
Attached Thumbnails Vibra-Technics motor mount install-image-1275678644.jpg   Vibra-Technics motor mount install-image-1782384289.jpg   Vibra-Technics motor mount install-image-268557821.jpg
Old Jul 21, 2014 | 11:06 PM
  #213
d1hojo07's Avatar
d1hojo07
Originally Posted by d1hojo07
I tried with the rear wheel up and down and a few different ways. I already gat an email back and will have a new one here tomarrow. Now THATS service. I hope they don't mind me sharing this email.
Hello Tim,
I am sorry to hear you are having problems with the mount.
We have sent you a new mount out, it should be with you tomorrow. Its actually a prototype based on the TC mount but with a top plate from an EVO version we have been working on. We are hoping this will fix the problem. The only thing to look out for is the clearance between the mount body and the motor casing (see pic of the EVO install) . You will need to use the original 3/8unc bolts to the motor as the EVO does not have the clearance for the M10 bolts we originally supplied. If there are ay fitting problems let me know.
It showed up the next day as promised. It went on much easier and seems relaxed now. Due to medical problems I wont be able to actually check it out for a while.
Old Jul 22, 2014 | 07:18 AM
  #214
mattVA's Avatar
mattVA
Originally Posted by kp877
The pin being in backwards is a known issue on some dynas. Pull the clevis pin and install it the other way and it should provide the clearance you need. Your vibrations however are not due to the mount.
Is there a service bulletin or is this just a fix devised to increase clearance? Mine is the same as chickenhauler's and opposite to yours. If it is indeed backwards according to some TSB etc I'd like to correct it if it could cause issues.
Old Jul 22, 2014 | 07:46 AM
  #215
br549A1's Avatar
br549A1
No bulletin. Something I found when researching. It creates more clearance.
Old Jul 22, 2014 | 06:45 PM
  #216
chickenhauler's Avatar
chickenhauler
I took some pics of the rear mount.
Old Jul 22, 2014 | 06:50 PM
  #217
chickenhauler
I forgot to mention, I could fit a popsicle stick under the bottom of the mount across the whole bottom. Another pic. Thanks everyone for your help!!!! Jim
Old Jul 22, 2014 | 06:51 PM
  #218
br549A1's Avatar
br549A1
Looks good doe hear nice and straight no popped rivets or twisting. Could be soft still but I'd call it as fine.
Old Jul 22, 2014 | 06:52 PM
  #219
chickenhauler
oops the pic
Old Jul 22, 2014 | 07:00 PM
  #220
chickenhauler
I'm half tempted to change it anyhow---it's only $100--- thats a small price to pay for a piece of mind. I better get this thing to stop the passenger peg vibration, mamma wants to ride!!! Jim
