Headlight (Low Beam) and Passing Lights will not work
Old Dec 2, 2020 | 05:13 PM
Fishhook68's Avatar
Fishhook68
Stage I
Default Headlight (Low Beam) and Passing Lights will not work
New Member here,,, so any help will be greatly appreciated. I have a 2001 FLSTF Fatboy. Hooked up a new taillight (Hogworkz Pro Integrated LED Taillight w/ Turn Signals). Hooked right up and works fine, High Beam works. but the Low Beam and passing lights are not working now. Checked all the fuses and took my Fluke to the connectors and getting all the right voltage at each point, and to the headlight and have continuity at each point as well. Question is, if the low beam is out will the passing lights still work? I'm not too up to speed on electrical wiring, so kind of at a stand still. Not sure if anything I am doing is even the right thing to do, so here I am, asking for yall's help, please and thank You!
Old Dec 2, 2020 | 05:49 PM
kel03's Avatar
kel03
I`d give Hogworkz a call, I suspect they`ll know what`s going on. May need a load equalizer installed. Drop by the Welcome Area and introduce yourself.
Old Dec 2, 2020 | 06:00 PM
RANGER73's Avatar
RANGER73
The passing lights and low beam are connected usually in the headlight bucket.
check the socket in the bucket first then confirm it is getting power.
Old Dec 2, 2020 | 06:30 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Since both low beam and passing lamps are inop, you know the open in the circuit is somewhere between the headlight switch and the point in the wire where it branches out to the headlamp connector and passing lamp switch.
Follow the yellow wire back from the headlamp connector, that wire will pass through 2 connectors.
Unplug connector 38 and check for voltage with your meter on the A side of the connector.
If power is at connector 38, move on to the A side of connector 24.
Ignition switch on and low beam selected on the switch of course...
Old Dec 2, 2020 | 06:33 PM
kel03's Avatar
kel03
How does this happen just changing out a tail light ?
Old Dec 2, 2020 | 09:58 PM
Dan89FLSTC's Avatar
Dan89FLSTC
The tail light has nothing to do with the headlamp, it is a different circuit.
Old Dec 2, 2020 | 10:22 PM
Vernal's Avatar
Vernal
I can’t come up with a reason why adding the new tail light would affect the low beam power. Light fuse supplies power to the Headlamp Hi/Low switch. High beam works so switch is getting power and the ground is good. Switch to Low and no power to low beam or pass lamps.
like Dan said check for 12V at connector 38A on the yellow. If nothing there I’d check continuity between the Y and BE at 24B with switch at low.
Old Dec 4, 2020 | 10:20 AM
Zanthamos's Avatar
Zanthamos
The FLSTF does not come stock with aux lamps so the spade connector on your low beam may be suspect, if the passing lamps were wired into the low beam by the PO I would check where the wire goes to power the passing lamp switch which is either an in line splice or a replacement of the spade connector on the yellow wire of the H4 connector.
Old Dec 5, 2020 | 06:43 AM
kel03's Avatar
kel03
Looks like a one time poster, guess we won't see if this got corrected.
Cootey
Electrical/Lighting/Alarm
16
May 9, 2020 10:06 PM
Lowboy2200
Jan 26, 2012 01:43 PM
harley-jones
Mar 5, 2009 05:10 PM
ozzy07840
Mar 13, 2008 05:57 PM
dclapp
Jun 11, 2006 07:26 PM
