Prep New Cylinders for Pistons/Rings
Old Aug 25, 2016 | 08:33 PM
mmesa005's Avatar
mmesa005
Default Prep New Cylinders for Pistons/Rings
I would appreciate some advice as to which grit hone to use and if anyone has used a Flex-Hone to prep their cylinders?
Thanks!
Old Aug 25, 2016 | 11:50 PM
Max Headflow's Avatar
Max Headflow
Hones...
240 grit is fine but the guy did it way too long. 320 would be better but dingleberry hones don't do that good of a job on cast iron liners.. the 240s work OK on Nikasil cylinders but you are really not trying to do much more then scratch them.. I've used 320s on 2 strokes after boring (honed to size with a good fixed).
If you look at the end of the post, there is still a carbon ridge at the top of the cylinder.. For std cast iron sleeves (ductile or whatever), it's better to use a fixed position hone like Sunnen, Goodson or Lysle. Make the cylinder round again, take out a little taper and take out the ridge.. Piston might rattle a little tho rings will seal well.
Old Aug 26, 2016 | 12:00 AM
mmesa005's Avatar
mmesa005
bwoltz,
Thank you for your advice!
Old Aug 26, 2016 | 05:21 AM
prodrag1320's Avatar
prodrag1320
these are new,bored to size cylinders,right? if they where honed properly,just clean,check ring gap & install.no need to ball hone. (we use 280 on our sunnen honing machine)
Old Aug 26, 2016 | 06:36 AM
beerman1378's Avatar
beerman1378
3rd Gear
Not to hijack your thread but I pulled my pistons and my cylinders look great. I going to get them honed. A top compression ring was stuck in the groove though. After I clean up the piston, the new same size rings would work correct?
Old Aug 26, 2016 | 08:10 AM
Max Headflow
Embarrassingly, I missed that.. What is more important is getting the cylinders clean before assembly.. The video doesn't show that..
Old Aug 26, 2016 | 08:16 AM
Max Headflow
I'd get the cylinders and pistons to an automotive / motorcycle machinist. Have him look at it.. Rings typically don't stick in grooves.
Old Aug 26, 2016 | 09:31 AM
mmesa005's Avatar
mmesa005
Yes, new cylinders. Glad you clarified that as I did see another video where they did exactly that. Moder often than not these videos don't provide enough explanation or reflect contrasting philosophies.
freud
Shovelhead
Dec 11, 2013 02:26 PM
barrygxl
Dec 2, 2011 08:40 PM
chad pickens
Exhaust System Topics
15
Aug 16, 2009 07:04 PM
straydog13
Ironhead
Aug 23, 2008 04:22 PM
05 Spring Class
Oct 6, 2006 08:28 PM
