Help identifying this bolt
Old Sep 28, 2018 | 11:03 PM
sgr60's Avatar
sgr60
Default Help identifying this bolt
Hopefully this is a quick & easy question - I'm working on an '01 Sporty, and I'm hoping someone can tell me what bolt is supposed to go here at the base of the cylinders. Is this just an engine case bolt? Hoping someone has the spec or part number.
Old Sep 28, 2018 | 11:28 PM
TwiZted Biker's Avatar
TwiZted Biker
Upper center case stud, replace that before you do anymore riding, can't help you on the part number, sorry.
Old Sep 28, 2018 | 11:32 PM
mmesa005's Avatar
mmesa005
I believe it is the engine timing mark access plug? Thread should be same as engine oil drain plug.
Old Sep 28, 2018 | 11:39 PM
mmesa005's Avatar
mmesa005
Old Sep 28, 2018 | 11:42 PM
TwiZted Biker
Not the timing plug kiddies, that's a case bolt. Later models don't have timing plugs.
Old Sep 28, 2018 | 11:46 PM
sgr60's Avatar
sgr60
I think I found the part number for the bolt and washer:
Case screw - PN 1028 and washer PN 6314W
(Also - definitely not running it like this - I just pulled off a chrome doodad that was on there, so need the new bolt before I run I again.)
Old Sep 29, 2018 | 04:57 AM
Kingglide549's Avatar
Kingglide549
Not kiddies -
it would be a timing plug for us old guys...not sure when HD deleted a basic timing requirement...
OH!
That's right, when they invented the trouble-free computerized BS that never fails!
Old Sep 29, 2018 | 01:21 PM
marcodarq's Avatar
marcodarq
just for the record, the 01 xl platform does indeed have a timing plug and hole, it's on the cam side in between the pushrods, the OP however is indeed looking for the center case bolt.
m
i'm pretty sure that HD didn't do away with the timing hole untill they went to the crank pick up sensor on the 04 and later stuff.
mm
Old Sep 29, 2018 | 08:20 PM
98hotrodfatboy's Avatar
98hotrodfatboy
It is a case stud and I believe the part number is 42449-89a. If you just go to your local dealer he will have it. I would also use the flanged lock nuts on each end...
Old Sep 30, 2018 | 11:54 AM
ROCKOUT Rocker Products
Sponsor
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
grubsie
EVO
Oct 15, 2020 12:34 PM
Chris Golding
May 26, 2019 10:44 PM
rquest
Apr 29, 2017 05:44 PM
rolodog
Mar 9, 2011 10:28 AM
OnTheFence
Mar 22, 2010 12:39 AM
