Pushrod cover?
Old Mar 15, 2019 | 10:13 PM
REW13's Avatar
REW13
Default Pushrod cover?
Not sure if this is a stupid question but....
How do you tighten up the pushrod covers? Think I have one coming loose?
Old Mar 16, 2019 | 06:46 AM
roussfam's Avatar
roussfam
They are spring loaded
Old Mar 16, 2019 | 07:08 AM
REW13's Avatar
REW13
Cool.. Thank you
One seems to have a little more play than the other three..
Old Mar 16, 2019 | 08:06 AM
roadmutt's Avatar
roadmutt
How old is the bike? The o rings get hard and compressed over time. They’ll be a bitch and a half to put together with new rings but will be tight.
Old Mar 16, 2019 | 08:26 AM
Tired's Avatar
Tired
You don't have the Screamin' Eagle P-Rod cover wrench and Spring Tension tool set?
Old Mar 16, 2019 | 10:20 PM
REW13's Avatar
REW13
It's an 01 fxdl, cams, gears and adjustable pushrods were added three years ago.
Old Mar 17, 2019 | 08:33 AM
roadmutt's Avatar
roadmutt
If you didn’t do the work yourself, take them apart and check. Or live with it.
Old Mar 17, 2019 | 08:57 AM
bustert's Avatar
bustert
make a wise choice in selection o-ring material. i run the silicon type and been there since 2002. buna-n will work but will fail after a few years. go to a crane or hydraulic shop and get some from them as they will have the nitrile and viton as well.
crewchief437
Aug 12, 2013 05:00 PM
Dustmaker
Apr 12, 2009 07:14 AM
electaRICK
Apr 14, 2007 05:45 PM
wheeler
Oct 27, 2005 05:51 PM
