Vague tap or knock
Old Oct 4, 2021 | 04:27 PM
Construct's Avatar
Construct
Default Vague tap or knock
Replaced lifters, pushrods on a 127 a while ago because of a bent pushrod in the rear cylinder.
Cam looked good no issues there. After setting the lifters three times with a cold motor, everything was fine except for a knock that is rpm sensitive in the front cylinder.
As the motor warms up it lessons quite a lot but never completely leaves.
Compression is good in both jugs but, I can't get rid of it. I run a Mik and know what a flat slide sounds like on an EVO, this is different.
Old Oct 4, 2021 | 05:10 PM
robarosa's Avatar
robarosa
Well, I'll be the first to say you'll need to post a video with sound so we can make a guess. Right now I'm guessless.
Why do you think the PR was bent?
Old Oct 4, 2021 | 09:27 PM
Max Headflow's Avatar
Max Headflow
127 what? Evo, TC, M8?
If you bent a pushrod, you probably bent a valve.
Old Oct 6, 2021 | 08:51 AM
fat00boy's Avatar
fat00boy
What caused the pushrod to bend?
Old Oct 6, 2021 | 09:15 AM
Screamin beagle's Avatar
Screamin beagle
I'll play...an evo based Ultima El bruto. But thats the 64000 dollar question...why did it bend O.P.? Was the bent pushrod in the front where the noise is now coming from?
Old Oct 6, 2021 | 01:34 PM
eriksweden's Avatar
eriksweden
maybe rocker hits cover ?
Old Oct 6, 2021 | 02:31 PM
Construct's Avatar
Construct
OK, here's the info.
The knock is in the front / exhaust when I put a stethoscope on her.
Valve is not bent and functions well / no oil entering into cylinder or down valve stem.
Compression is good in both jugs.
Pushrod that was bent and bend is not visual unless you roll it on flat surface.
That pushrod came from the rear cylinder.
I changes out all pushrods (OEM to smith Bros) and changed out all lifters.
Doesn't sound like normal Mikuni slide slap.
No exhaust leaks found nor intake leaks.
Motor has been rock solid for years with 20k on this motor.
Old Oct 6, 2021 | 02:33 PM
Construct's Avatar
Construct
Max is that you?
Still here after all these years?
Old Oct 6, 2021 | 05:41 PM
robarosa's Avatar
robarosa
I would put a borescope down the plug hole to see what the top of the pistons (both) looks like.
Old Oct 7, 2021 | 01:53 PM
marcodarq's Avatar
marcodarq
how deep in the lifter are you setting the pushrod?
m
Bobbed
Jul 31, 2017 10:50 PM
micalaut
Engine Mechanical Topics
Jun 2, 2017 11:58 AM
pittz5
Apr 11, 2015 08:09 AM
Fear2722
Apr 20, 2013 08:42 AM
Spitshine
May 3, 2009 10:48 AM
