S&S Pushrods - Reg Adjustable or quickee
Old Jun 23, 2024 | 07:13 PM
Adam76's Avatar
Adam76
Originally Posted by NDF
Thanks for the reply, luckily I got the quickee pushrod covers! Did you have to take off the tappet covers.
you shouldn't need to take the tappet covers off. That's Why they're called quickee pushrods.
Old Jun 23, 2024 | 07:25 PM
NDF's Avatar
NDF
4th Gear
That is correct for the quickee adjustables, I agree. I am trying to confrim if the tappet needs to come off for the regular adjustables..Thank you
Old Jun 23, 2024 | 07:29 PM
Rounders's Avatar
Rounders
Download the instructions. My understanding for my bike the tappets do need to be removed for regular. Not crazy about S&S instructions they have every year in there and you have to sift through. Also pisses me off they don't print instructions anymore.
Old Jun 23, 2024 | 07:30 PM
ChetB's Avatar
ChetB
I installed the complete S&S kit when I replaced the cam chain tensioners.Yep, just remove the tappet blocks.You'll have to install the T blocks and pushrods at the same time if you use the kit I did. Kind of a handful but very doable.I used the regular adjustables rather than the quickees because they look a lot more robust. Follow the instructions to the letter and you'll be fine.
Old Jun 23, 2024 | 09:11 PM
memphisharley's Avatar
memphisharley
yes..
Old Jun 24, 2024 | 09:25 AM
NDF's Avatar
NDF
4th Gear
Awesome thank you!... does the lock nut get tightened to the bottom nut
Old Jun 24, 2024 | 11:12 AM
memphisharley
yes
Old Jun 24, 2024 | 07:20 PM
ChetB's Avatar
ChetB
Make sure you get that lock nut good and tight!
Old Jun 25, 2024 | 09:19 AM
NDF's Avatar
NDF
4th Gear
Thanks everyone for all your help!!.. This group is great. Should be installing Thursday
Cazic2005@yahoo.com
EVO
Mar 8, 2022 06:54 PM
crzoomb
Jan 17, 2021 06:46 AM
chiefy305
Nov 29, 2020 08:09 AM
rydahog
Dec 7, 2017 04:44 PM
kickstarter1340
EVO
13
Nov 15, 2013 06:02 PM
