Cam Uograde
Old Mar 10, 2025 | 09:46 AM
Lakejunkie9's Avatar
Lakejunkie9
Stage II
Default Cam Uograde
Going to put in a Woods TW-222 cam in my 2011 Road king. Do I have to change out the cam plate and oil pump? That doubles the price of the cam upgrade.
Old Mar 10, 2025 | 09:54 AM
memphisharley's Avatar
memphisharley
no way to know until you take it apart and inspect the parts. btw...you will love that tw222.
Old Mar 10, 2025 | 01:16 PM
r8r_4_life's Avatar
r8r_4_life
I have 2010 SG with 8XXX miles and I recently did a stage 2.
My indy suggested only a cam since the bike has such low miles, but I ended up changing the cam, cam plate, oil pump, pushrods and tubes, tensioners, etc. I don't think I HAD to do it, but I figured since it was open, might as well. It does raise the price, but I was looking more down the road as I don't plan on upgrading to a new bike.
I'm doing the same thing with my primary. With the stage 2, my clutch is slipping in 5th gear so I'm upgrading that and changing the compensator as well. Might as well since it's already open.
Old Mar 10, 2025 | 03:57 PM
Hammerhead Pat's Avatar
Hammerhead Pat
I put Andrews 48h's in my 2011 RK with 55k miles on it and didn't mess with cam plate or pump, bike runs flawlessly.....
Old Mar 10, 2025 | 04:05 PM
Spanners39's Avatar
Spanners39
It isn't necessary.
Old Mar 12, 2025 | 07:14 PM
98hotrodfatboy's Avatar
98hotrodfatboy
No need to replace the oil pump or cam plate unless they have issues.. Definitely replace the cam bearings and what tuner are you going with or you going to have a dyno tuned? The 222 performs well in a 103 you'll like that..
Old Apr 19, 2025 | 01:24 PM
USMC2010's Avatar
USMC2010
I am doing this cam soon, will also be replacing the cam plate and oil pump.
Old Apr 19, 2025 | 02:15 PM
curtisjames91's Avatar
curtisjames91
I new here but got the same response with my 15 flhtcul 103 open it up if everything looks good put in the cams if there’s wear replace what’s worn
scottybtattoos
Feb 15, 2024 07:41 PM
leftyjm
Milwaukee Eight (M8)
39
Feb 2, 2024 08:33 PM
Weeboy1
Twin Cam Motors
Jun 9, 2021 01:41 PM
mjkacz7
Engine Mechanical Topics
43
Sep 3, 2017 10:06 AM
djack
Oct 15, 2011 12:40 PM
