Oops
Everything is apart, and now I'm taking a beer break.
That snap ring on the output bearing is a real SOB, isn't it?
So far the only glitch I've run into is removing the trap door gasket. The bottom part (down by the exhaust bracket) is fighting me. Got some aircraft paint remover working on it now.
As it sits, the trans is back together and the inner primary race is installed. I test fit the inner primary and it looks like the race position is right on.
This has gone incredibly slow, mainly because I had two friends stop by in succession. The first one had to tell me all about his tribulations getting his in-laws house refinanced. The second got into it with his wife and needed someplace to hide for a while.
After all this, I'm surprised at how small the pile of removed parts is.
Other than the inner primary bearing and seal, that's pretty much all of it.
Other random thoughts: The shifter pawl spring looked fine, so I just left it. It sure is a hell of a lot easier adjusting the shift pawl with the inner primary off the bike. One of the reasons I like doing jobs like this is it lets me de-gunk places I could never get to otherwise. Removing the crankshaft seal was no fun. Why did the MoCo use such an obnoxiously small snap ring on the shift pawl? I found a better one in my supply that still fits correctly but has bigger ears. Whatever that Cosmoline like goop Andrews uses is no joke. Stuff does not give up easy.
Had hoped to get this buttoned up today, but it's beer thirty and I'm out of gumption for now.
Have friends stop by and it's all good till someone pops a tab.
Amazing how fast the work comes to a halt.
It's time to stop when that happens LOL
Glad your getting it
WP
I don't like the clamp tool to hold the pulley, I put the belt on it, sit on the bike holding the brake to torque the nut to 50, then rattle gun to 45 degrees
Got her on. God willing, this never comes apart again.
For crazy reasons I won't bother going into, I drug my air compressor down to my shop. So I'm left doing this job the hard way. Ended up recruiting my daughter to stand on the brake while I cranked it down. This beauty worked out perfectly.
PS: I think I'm done for the day.
Somehow I had the idea that the inner primary bearing would just pop out. At most, I figured a few taps with a socket and a dead blow would get it there.
Don't think so. Looks to be well pressed in. I don't have a press in the garage, so I'll have to take it over to Mark's tomorrow.
Should have cleaned the inner when I first took it off. The wobbling pulley didn't do it any favors, and there is a very rough lip on the edge where the seal goes. It should be usable, but is going to take a little massage.
JR
